What would be a good color for a wash on a flat white interior?
I was thinking about close to neutral gray…
i went through the same question last week and got a few good peices of advise…light greys or if your using oils a yellow ocher works as well,you can also do a pastel dusting with tans,or light grey,depending on which tone you prefer
I generally use a light gray, mostly neautral gray for sludge washes. Black is a bit stark, but gray is just enough to show shadow and a bit of grime.
