Hi Guys,
HI–ANYONE WHO’S TRYING TO VIEW THIS POST, PLEASE BE PATIENT; ['VE APPARENTLY “EXCEEDED BANDWIDTH” FROM PHOTOBUCKET WHICH MUST RESET NOW LATER IN THE MONTH. DOESN’T REALLY MATTER, AS I WON’T BE UPDATING TIL I ET BACK NEXT WEEKEND. THANKS FOR AL THE VIEWS, COMMENTS AND YOUR INTEREST!!! BE BACK SOON!!
Well, I’m back in the saddle again with a build I’ve been working on for a while here—slow going, as I’ve been having a number of setbacks with it. Repainting, experimenting, and having to rebuild lost parts. I’ve finally got it to where I can show some progress.
First of all, the surface of the model is too smooth for a big steel beast…I had to fill in the joint between the first hull addition that you put on.
I used my Dremel to bump and grind in some texture to the hull.
Not sure if you can make it out here…
Next—I"m adding zimmerit from Tamiya putty. Just trying something different; usually I use Squadron’s White Putty. There’s really no difference at all, in my opinion, after using it. These are Tamiya’s Zimm rakes,
Got some “Field-applied” mojo going here. The three protoypes built were allegedly used in combat at the end of the war; I want to portray mine as being dressed for war, with some late-additions of zimm and a cool paint scheme.
Next, the bottom of the Trumpeter model has no detail. I used the bottom of the HobbyBoss “Hintern” model as a template for the mods,
This kit has, oddly, a turret interior—but no hull interior. I decided to build it anyway, as an exercise. This was where I did some experimenting–I used the hairspray method to do some weathering on the floor. I mixed my own primer color from Tamiya, and had a few go-arounds of stripping it all to get a “right” color and weathering mix. All the parts were reduced to sub-assemblies to facilitate the painting and assembly.
My experiments with the hairspray chipping. I reduced this somewhat since the photo.
I had to paint the shells before I could put them in the racks. I like the green shells as portrayed in front of the Panzermuseum in Germany. he others, I painted steel, as metal shortages saw these shells made of steel later in the war.
The turret top,.
Top & bottom
The lower turret basket, finally painted, weathered and put together. I plan to add some minor dirt to this as well, from the crew’s boots.
The turret basket installed. The fit is tricky here; it was a chore to get this all lined up and every part connected and painted properly. I broke off all of the seat mounts at one point or another, and had to rebuild them all. Ugh!
Well, that’s it or now—I have to work on the gun assembly next. I expect that to take a week or so with my schedule lately. [:|]
Thanks for looking in, guys! Any comments and critiques are always welcomed and appreciated! [:)]
