What would be the best glue for all of the clear parts on the visible P-51. Most canopy glues aren’t too strong, so something stronger and crystal clear would be much preferred
Thanks.
Thanks.
I built one (Monograms Phantom Mustang) with Tamiya Extra Thin. The other I built with MM glue (with the metal tip) when I was little
I saw that kit in the last squadron flyer,anybody built it?
If you coat the clear parts with future you could use super glue without causing hazing.
Yes, and it’s a good model. Believe it or not it was the only 1/32 Mustang D for a long time.
I would use CA, but then again, I always use CA.
If you building a Stang, why don’t you consider joining my Mustang Build. Just follow the link below.
Try the regular Tamiya liquid cement.Tac it on at major points then work your way up for final seal.Overall seal the model w/non-spar varnish w/overnight during time.The model is ment to display the internal parts and working ability .
Epoxy is also an old standby for gluing transparent materials- no fogging.
I kinda wanna build that kit,but gluing clear plastic without fogging scares me
What ever happened to the technique of coating clear canopies with Future floor wax to prevent fogging by CA.
No longer valid or not practical for an entire kit in 1/32 ?
