This is URGENT, protect yourself asap. I have had 3 people come to see me today already about this on there home PC’s
Q. My computer keeps restarting after something to do with a Remote Procedure Call (RPC) terminates unexpectedly. WHAT THE HELL IS THIS?
A. You’ve been hit by the RPC exploit, a serious flaw in the Windows NT line of Windows products (NT, 2000, XP, and 2003 Server). If this has happened, your system has been compromised, and your only option is pretty much to reformat and reinstall all your programs from known-good sources. Any single part of your system could be infected with who-knows-what, as the RPC exploit gives a malacious user unrestricted access to your system.
So Protect your system before you have to reformat (its the only solution once it’s happened), get the patch on ASAP People
What does this mean. It seems that a worldwide worm/virus is circulating. If you have Windows XP, Windows 2000 or Windows NT 4.0…you will need to download this patch. About 1/3 of home uses have been hit already in one day. This is a major worm, and could result in doing a complete reformat of your system.
If you have been infected, you will no becuase your system will reboot over and over again. If this is happening you will need to download this fix:
http://securityresponse.symantec.co…er/FixBlast.exe
All those who have not been infected and those who were infected and downloaded and installed the fix above, you will need to get the patch off of Microsofts page…
http://www.microsoft.com/technet/treeview/default.asp?url=/technet/security/bulletin/MS03-026.asp
If you are using 2000, download 2000…if you are using XP Home or Pro…download XP 32bit.
If you are not using 2000, XP or NT 4.0, you are safe.
