Vintage SMP 1961 Corvette convertible- "saved'
This vintage SMP model of a 1961 Corvette convertible was in my “junk” model collection of assorted parts and unfinished glue bombs from the past. Its badly painted body was intact, the interior was partially finished but the chassis had been cut into two pieces and a 1/2 inch section removed and gone forever. The engine is not from the original kit, the wheels were ruined from a heavy application of glue which had totally distorted them. Other lost parts had to be substituted or scratch built. Carpeting was added to the interior and trunk. Body was stripped of black paint and repainted a matte white.
Considering where it came from, it is fortunate that all the wheels roll and that it is now finally complete after a month’s work. Thanks for looking…
Very nice salvage job! [t$t] [t$t]
Stay safe.
Jim [cptn]
That looks fantastic. I love the colors you picked.
Hi!
Nice save so far. You need to add a crossmember Under that engine trans assembly. I like all the rest. Where did you get the headlight Bezels? Those are unique to one Vette I know of.
[quote user=“Tanker-Builder”]
Hi!
I’m glad you mentioned the crossmember as the engine/transmission problem was a sore spot indeed. I will address this right away as I intended to do something regarding it before the photos were taken and was looking for a response regarding this are in particular.
As for the headlights, now that posed a real problem as I could only locate TWO of the plastic lenses that were in the scattered kit parts. I was never able to locate two others and the couple of plastic substitutes I did find nearly fit but were a tad oversize. My last resort was to use a leather punch bearing the correct diameter and use some paper-backed foil as lenses.
