Looking for a way to make bench seats in a truck look old, used, “sat-in”…any suggestions?
Take a look at Shellback’s Zil 157 truck build; On Page 11 then to page 13 for the end result.
Should give you a good start.
http://cs.finescale.com/fsm/modeling_subjects/f/3/t/148249.aspx?sort=ASC&pi240=11
I use an ogive-shaped grinder in a Dremel tool to carve a slight concave area on the cushion top. Then priming and sanding to get the marks out.
Depending on how extensive you want to get, can make seat cloth out of wet paper and exposed springs coming through.
