well I ran into a snag on my Phantom build already. I cleaned the resin exhaust nozzle with water and dish soap, let it dry and then primed with vallejo 77.660 gloss black primer. I am prepping it for using metal colors. it been a week since i ipainted them. Today I put Tamiya tape on to start the first coat of paint and when ii removed the tape the primer came right off. Turns out I can peel it off with my fingernail. I
So the question is do i need to do something different in my prep or do i need to primer resin parts with a non acrylic primer first? Any advice would be reall beneficial.
I use Vallejo surface primers… they don’t do too bad. It helps if you coat which ever part you’re going to prime with a flat clear varnish first. Something to keep in mind about the surface primer… it’s intended purpose is giving something for acrylic paints to “bite” into. Do not expect it to be as durable as an enamel primer. I have read plenty on the interwebnets of guys who were disappointed when they could not sand out any imperfections that were found after the primer went on… that is not the intended purpose for Vallejo Surface Primer.
