Vallejo Model Color - preparing for use with airbrush
Is there a preferred way to thin Vallejo Model Color (not Vallejo Model Air) for airbrush use. Is there a preferred thinner? Is the result a soft or a hard paint surface? Is there anything that can be added to make the surface harder.
Before I purchased these, Vallejo told me that they can be thinned and airbrushed. Now some friend have told me that they will produce a soft surface which MUST be covered with Future or have a hardener added to the paint and thinner.
All suggestions will be appreciated. Thanks
Bear in mind I haven’t used these, but from my knowledge of coatings technology, if someone is getting a soft surface just from thinning the paint, they are using the wrong reducing solvent, or doing something wrong when airbrushing, or did not prepare the surface properly.
Aaron Skinner of FSM, in his pull out from an issue date I don’t recall, said that the recommended thinner was their Model Color Solvent, 70524. The Vallejo website says you can use distilled water—their instructions specify it. There is also an implication, at least, that alcohol may be used as a cosolvent (which would speed drying).
Aaron found no defects in the cured coating with respect to surface qualities or adhesion. He did say it required numerous thin coats to cover, but that’s not necessarily a bad thing, especially considering that these are formulated to be thick in the bottle.
There is no such thing as a “paint hardener.” There are accelerants that can be added to some paints, but they often change the performance of the paint in less than desirable ways.
I suggest you experiment and practice on some scrap before using it on a kit. I always do this with a new brand of paint, as well as test it for solvent compatibility.
Acrylics are NOT enamels, and CANNOT be treated or used the way enamels are.
Thanks so much for your reply. Further reading points out that Tamiya and other alcohol-based acrylics are based on older types of paint formulations. The newer modeling acrylics such as Vallejo, are based more water formulations. At least that is what I have read. Some links even mention the use of Golden acrylic paint thinner.
Vallejo is best thinned with distilled water. The basic line is intended for brush painting & is widely used by figure painters, It can be thinned & sprayed with an AB, but their Air Color line will give better results.
BTW… DO NOT try & thin Vallejo with alcohol. You’ll end up with a pulsating, congealed lump of goo. I learned the hard way [:(].
Regards, Rick
I agree with rjkplasticmod. I use Model Color a lot and distalled water works great. I mainly use tap water with a drop of Liquetex flowaid and slow dry.
But do avoid alchool. It will get nasty quick and that is from experince.
This is what will happen.
http://www.happinessismandatory.com/misc/Models/PolarLights_Enterprise_NCC1701_1_1000/Build_Images/ent_060909_base_Dish.jpg
Most of the paint I used on my Viper and Polar bear were airbrushed Vallejo paints
http://www.happinessismandatory.com/misc/Models/Colonial_Viper/Build_Images/Viper_Finished_1.jpg
http://www.happinessismandatory.com/misc/Models/Wave_Polar_Bear/Build_Images/PB_090514_Finished_6.jpg
Rick and Greasy, what alcohol did you try with Vallejo?
90% isopropyl alcohol from wal-mart
I use it with tamiya pants not problem but Vallejo just became stringy.
Vallejo makes their own thinner that comes in the same type bottle as their paints (they call it “diluant”). Online vendors that carry Vallejo paints usually have it.
As is the case with other brands, usually it’s recommended to use the brand’s proprietary thinner. Personally I haven’t tried thinning Vallejo with water, but as indicated above I’ve heard it works fine.
I’ve airbrushed Vallejo a number of times after thinning it with distilled water as recommended by the mnanufacturer. It has held up well during the subsequent painting process and on the finished subject.
To add to what’s been said already, I highly recommend using a flat primer coat (of any type of paint) under Vallejo to help give it some “bite”.
I’ve found that it does very quickly pick up a sheen from handling, so I wonder if that’s what some people might consider “soft”…
Just did some quick and dirty compatibility testing, and the stuff is completely incompatible with either isopropyl or ethyl alcohol.
“[U]se distilled water…They are 100% water soluble…As mentioned before, …use only very clean water…‘dilution rate’ and it will be noted as ‘parts of paint’ to 'parts of water’… you may notice that paint will begin to dry on your palette. As soon as this happens, add the necessary amount of water and/or paint…”
Source: PAINTING FIGURES WITH MODEL COLOR Acrylicos Vallejo
Can they be ANY clearer about this? Thin Vallejo with WATER! No need to experiment with more costly products and other brands’ proprietary thinners. Use Water. Distilled water costs less than $2.00 a gallon, even with a Poland Springs label on it.
I think I payed $.79 a gallon at Smart & Final here. [:)]
Yeah, but it doesn’t say POLAND SPRINGS on it…nor does it go to 11! [:O]
Anyway, that could lead me to yet another, though unrelated rant. If you distill the water, don’t you eliminate eveything but the essential two H’s and one O of each molecule of water that is supposed to make Poland Springs water special? [^o)]
The purpose for testing was to determine whether or not an alcohol could be used as a cosolvent to modify coating performance. For example, Tamiya and Gunze are best reduced with an alcohol solvent, but will tolerate small amounts of distilled water, which evaporates more slowly. Cosolvents are just another tool in the box, like using an adjustable crescent wrench instead of one the exact size.
Vallejo’s site mentions on the Model Color page that some of their paints (Colorima line) are alcohol-based and not water-soluble.
" A few metallic pigments (in an alcohol base) are included in the range, since these give a harder brilliance than the waterbased metallics. (Please see “ Liquid Gold ”)."
From the Liquid Gold link:
"Colorima is a range of 30 radiant colours, manufactured with permanent dyes which are not water soluble. Objects painted with Colorima are lightfast and waterproof, and can even be cleaned in a dishwasher.
Colorima is used mainly in hobby and handicraft painting, in colouring dried or artificial flowers and the tinting of wood, leather, cork and figures cast in resin, gypsum and marble dust compounds.
All colours can be mixed with one another, with Medium or Gloss Varnish. Brushes and painting tools have to be cleaned with alcohol, and Colorima itself is classified as flammable due to its alcohol content, although it is not toxic in normal use. (See “ Safety-Alcohol ”)."
I had not heard of the Colorima line before reading that. Seems pretty CLEAR to me that some of their paints are in fact alcohol-based and NOT water-soluble, although I’m guessing Colorima isn’t used as extensively by scale modelers as the Model Color or Air lines of Vallejo.
As a clarification to my previous post, Vallejo’s diluant is intended for their Model Air line of paints.With regard to these, their diluant is specifically recommended:
“Formula: The Model Air colours are manufactured with permanent fine arts pigments, and formulated especially for air brushing. The extremely fine milling of the pigments provides the model painter with the assurance of an even and smooth paint film, allowing for many coats of colour. Colours can be mixed with one another, diluted with water, Model Air Thinner or Varnish or even alcohol, according to the effect desired, but we recommend the use of Model Air Thinner since this product conserves the properties of the colours.”
And who said anything about using other brands’ proprietary thinners with Vallejo paints??? No one so far as I’ve read.
I do spray both the game color and model color line from vallejo when I need a specific color, and generally have good success. I do agree they are a bit ‘soft’ or more specifically, aren’t very durable to the touch. A good top coat is a must!
Here is my method. I mix 2 parts diatilled water: 1 part golden’s airbrush medium (available at any art supply store such as Michaels or Hobby Lobby). I keep a small container of this pre-mixed in an empty contact solution bottle. To this mix I add 1-2 drops of Future. This gives the paint some ‘toughness’. From this container, I thin to the desires consistancy.
One more VERY important point. Shake well, shake some more, then…shake. After that, I HIGHLY recommend straining your paint. Acryls in general, but especially Vallejo, will have little paint boogers that will either clog up your airbrush or ruin your finish.
Good luck!
Chris
My biggest criticism of Vallejo, so far, is their packaging. Shaking is simply ineffective in a container that small if the viscosity is at all greater than water. It’s simple (okay, hydrodynamics isn’t that simple) physics.
As for Chris’ suggestion to strain your paint: never put paint in an airbrush that hasn’t been strained. If you do, you are tempting the airbrush and paint gremlins, and they’re vicious little bastards…
I hadn’t thought of adding Future, as I’ve also noticed that they dry “soft”…I’ll have to give that a whirl.
Just remember, add the future to your thinning mix, then thin. I never add future to the paint directly, tend to get waaayy too much future, which can really make a mess!
