Ok, so i know this topic has been thrown about a bit over the last few weeks, but, I still can’t seem to find the answer i need.
After hearing how great Vallejo Air is and watching some youtube viddies of Game Miniature painters with their Vallejo, i went out and bought two bottles over the weekend. I didn’t buy any Vallejo thinner.
Anyhow, before loading them into my brush, i experimented with all the thinners i have on hand to see which one would clean out the brush the best, and this is what i found:
Mr Hobby Aqueous Thinner - seemed to thin ok and clean up ok, but doesn’t tear through it like Windex through Tamiya (my standard go-to a/b cleaner).
Tamiya X20A - similar to Mr Hobby, ok, but not overly impressive.
Tamiya Lacquer Thinner - i was sure this would be the best, as a previous thread indicated Lacquer thinner to be a good cleaner of Vallejo. Not Tamiya’s. This just curdled the paint and caused the pigment to clump together in a mess.
Mineral Turpentine - no reaction. Like mixing balsamic vinegar and olive oil - no mixing of the two liquids.
Acetone (nail polish remover) - worst of the bunch - causes substantial clumping and gumming. Managed to ruin a brush whilst i was mucking around with this little experiment.
Windex - did not worry about trying as i heard this really causes a mess mixed with Vallejo.
Sooooo…my question - If i want to use these paints, MUST i use Vallejo Thinner to clean up properly? Mr Hobby and X20A did an ok job, but not like i’m used to (as i said, i normally use Windex which tears Tamiya apart).
As it stands, i’m inclined to cut my losses ($10 being the two bottles i bought) and not worry about trying these paints if i have to then buy their proprietary thinner.
I like using Tamiya and Gunze for their cheap and easy clean up, but, i thought i’d at least see what the fuss is with Vallejo Air.
Further, i will add the Vallejo Air is much thicker than what i’m used to and think it needs to be thinned further, despite how it’s pre-thinned.
As you have made very clear, the biggest problem with painting with acrylics is the need to keep multiple kinds of thinners around. For me, Vallejo is one of the easier ones. I just thin with distilled water and a couple drops of windex in the AB cup. It takes a little bit of stirring, but I’ve never had a problem spraying it when thinned that way. Try it for yourself. I’ve read conflicting accounts on just about everything on the internet.
But your real question is about cleaning the AB. I’ve never let Vallejo dry in the AB, so I don’t know what it would take to get it out then, but I have good success using Windex to clean it out. If you’re just trying to run something through the AB, with no scrubbing, I don’t know how that would work. I haven’t found any paint that clears out of the inside of my AB completely without some rubbing with a pipe cleaner and some kind of cleaning fluid.
Chris - For me, the Vallejo Model Air has been really good to work with, sometimes I’ll just thin with distilled water, other times their own thinner. For airbrush cleanup I run a couple of water rinses through, then paint store lacquer thinner. At dis-assembly I find very little color remaining anywhere, then cotton buds, interdental brush and lacquer thinner finish the job.
I think one thing to consider, a name branded product is often quite a custom mix of ingredients, not always compatible with another manufacturers product, although called by the same name. Tamiya’s lacquer thinner may be something altogether different than a paint stores generic lacquer thinner, since it’s intended use is for Tamiya acrylic paint. When I smell Tamiya X-20A it seems like Vodka, more than store bought alcohol.
In fairness to most of the hobby paint makers, I consider it important to stick with their products for mixing into the final blend for application. Example: Tamiya’s thinners are reported to possibly contain additives for aiding in flow characteristics, and helping to prevent tip dry. I do find Tamiya works better for me with
X-20A, rather than alcohol or water for thinning. Same for Tamiya lacquer thinner, it does better for me than generic.
You’ve come this far in your testing, give the Vallejo thinner a try, I think you’ll like using it then. But do remember, Vallejo acrylics and alcohol are NOT in a friendly relationship. (Personal experience.)
Chris…Ok, glad I stumbled upon this thread. I too have just recently started picking up Vallejo AIR bottles. One of the principle reasons I wanted to go this way is the economy of use. I have wasted so much Tamiya Color over the years by pre-mixing, I wanted to go straight from a bottle. So, enter Vallejo AIR. Now, I will admit I am not impressed so far. I was of the thought process that this stuff was ‘good to go’ right from bottle.
I see from above you are still thinning before spraying? I’m scratching my head on that cuz like I said I thought it was good straight outta the bottle. Now, I’ve only really tried the metallics and recently (last night) Interior green. All of these, I went straigt and found it a bit thick. I have been cleaning with water to get out the bulk, then finishing off with a shot of amoniated cleaner which seems to be working. I haven’t taken the AB apart to see if there is residue, but, now I’m going to.
My biggest prob is, our LHS got this big, beautiful rack of VA but that’s it. I talked to the owner and told him of the problems people are having cleaning this out and he was surprised. He thought you could just use other products/alcohols/ etc. Anyway, he ‘said’ he’d look into the Vallejo cleaner, but, I won’t hold my breath.
Folks, the Vallejo AB Cleaner doesn’t remove dried Vallejo paints. Use lacquer thinner or denatured alcohol to remove them. Don’t clean your AB with IPA or Windex after shooting Vallejo paints. Doing so will likely create a gooey mess.
@Chris-K - i note you say not to use Windex to clean the a/b - is it just dried Vallejo with which this will cause problems? I note a few posts above BarretDuke refers to thinning with a few drops of Windex and Distilled water. Just curious if there is a different effect between dried Vallejo and fresh liquid Vallejo.
@Patrick 206 - that is a fair point about using a manufacturer’s proprietary thinner. I wasn’t aware that Tamiya thinner also had other advantages for use with their paint. My only issue is, as Chris-K stated, their own thinner won’t remove their dried paint.
@Rob - I agree, seems a lot of stores are starting to stock Vallejo now, I’m assuming because gamers like their brush painting qualities too. Also, Gunze is becoming harder and harder to find here, so i wanted to branch out into a new range to see how i liked/disliked it. Further, Vallejo have a huge colour range, so that’s always a bonus.
I didn’t see any mention of Testor’s Airbrush cleaner which I use with great success with Vallejo (both Model Color and Model Air).
As far as your comment about spraying from the bottle, there is another thing to keep in mind. Air pressure is also very key. Vallejo states that it should be sprayed at 20 to 25 psi. If you are spraying at 1 bar (15) or less you won’t have much success without thinning it down.
John, thanks for the suggestion. Unfortunately Testors A/b cleaner is one of the harder things to find close to me. To be honest, i’ve never seen it. In fact, i don’t even know if you can buy Testors acrylics here in Australia, only seen some of their enamels.
As for air pressure, i spray at 25-30 psi, but still thought the paint was a bit thick compared to my normal mix, but good to know too.
Chris, yeah, the colour variety is, quite simply, overwhelming when i’m looking at the rack. I’m used to good old standby Tamiya so when I’m faced with this mass of colour, I get confused by the names and how they ‘equal’ what I 'm used to.
The current issue of FSM warns of mixing Vallejo paints and Windex.
After reading a few horror stories posted at another forum, I tested Vallejo Model Color/Air with Windex. When Vallejo started to dry, I used Windex to clean it. The mixture of Windex and Vallejo became a gooey mess. I tried with IPA. The same gooey mess. Imagine a gooey mess inside your airbrush!! I don’t know how Windex/IPA would react with still wet Vallejo.
Anyway, after seeing the gooey mess, I clean my ABs with denatured alcohol or lacquer thinner if I have to shoot Vallejo stuff.
@Rob - hahaha, same problem. I was standing there trying to figure out what was the closest match to XF-60. I ended up buy two, one for the base and one for highlights.
@Chrisk-k - i missed didn’t pick up on that in the current issue. Will have to go and re-read. Thanks for the heads up. i’m going to go and get some Methylated Spirits (aka denatured alcohol) today and just use that. i might see if i can thin with it too.
I only recently started using Vallejo paints but I’ve always cleaned the airbrush with Windex. I guess the trick is to clean it immediately. As soon as I’m done with a color, I dump the paint and pour in some Windex. A couple of rinse/spray cycles and that’s as clean as it’s going to get without a teardown. I got lazy once and had some residue on the needle but some Tamiya acrylic thinner on a Q-tip melted it right off.
I thin it with Tamiya acrylic thinner but only because it’s all that I have. So far, no probs.
Regarding the “right out of the bottle” sprayability issue… I’ve read that Model Air pigment is milled finer than Model Color so that it works better in an airbrush. I CAN spray it without thinning but I really have to crank up the air pressure and then it comes out grainy. I always just assume that I’m going to need to thin everything.
