I had not built a model in over two years {moving,back&shoulder issues}- So needless to say I was as rusty as a nail on a farmers barn! First tried ICM’s Spit Mk. XVI. Total failure, Then onto ZVEZDA’s 109- The agony of defeat again{read instructions do not assume!} Now my 2nd ZVEZDA 109 is going quite well- SUCCESS AT LAST! I am on a roll now and glad too be building once again.
Way to stick with it, Bob. But, to burst your bubble…Can’t count on instructions in all cases.
Lyle.
if at first one doesnt succeed , try , try again…im always in that mode…
‘if at first you don’t succeed, keep on suckin’ til ya DO suck seed!’ The Three Stooges
Hi , Fella !
Glad to see I am not the only one in this category . When I got TRUMPETER’S U.S.S.NORTH CAROLINA it would’ve been a disaster if I had followed the instructions .They have you build the hull and above deck details ( without Bottom ) before finishing and then tell you to put the bottom on . This is a recipe for disaster !
By the way Geezer , how many times have you seen just this problem ?
I am impressed with Trumpeters 1/32 a.c. I have nine 1/32 P-47’s yet too build. But there 1/48, seem to be sparse and a little lacking. Hull last ? I’m not a ship builder, Full size submarines, yes, plastic ships, no. But- that would be a head scratcher. Turn out O.K.?
This is why I do so much dry-fitting and looking way ahead in the instructions and pretty much “building in my head” I guess would be the best way to put it, prior to actually laying any cement down on parts. All too many times I’ve found easier ways of assembling something than had I followed the kit maker’s instructions to the letter.
Exactly, sometimes I’ll even go out of sequence. Not because I don’t like how the manufacturer has the assembly laid out, but how I want sections too come together. As long as final assembly is not affected. Sometimes I just want to build the wings before the fuselage,or the landing gear before the motor. But you are correct- DRY FIT FIRST! A hard lesson I have too keep on teaching myself.
Finally having success with ZVEZDA’S 109F4, Almost through, fuselage being mated to wings. Small sanding then off to paint. Next up Tamiya’s P-47D, Half-pint Maj. Robert S. Johnson’s first E.T.O. '47.
Got that wrong his first '47 was a “C” model. Was still half-pint.
How about some pics of the Zvezda 109? I’ve built a couple Zvezda aircraft kits, and even though I was impressed, I could see how they would be a little tough for someone getting back into modelling again…
Sorry about the delay, still trying too catch up from the snow,and then the rain. I was also impressed with Zvezda’s BF-109F. Some things are a little fidgety, but it’s getting built. Have to dust off the ol’ Nikon then I’ll get some pics up.
Tankerbuilder, I usually find it in the poor visuals and accompanying written instruction. I guess my visual acuity isn’t what it used to be. I can spend minutes looking for a part or where it goes based upon the destructi, uh, instructions. Lyle.
