Trumpeter’s USS SSN-21 Seawolf Attack Submarine 1:144 - by “Tazmanian”:
This is from my latest page:
http://www.falconbbs.com/model51b.htm
Comments and suggestions are welcome!
No comment.
[:D]
LoL!
Mind you, there’s probably somebody out there, somewhere, agonizing over what is the correct Afrikakorps desert tan to paint their “Rommel’s Rod” they just got .
subfixer, what are those 6 rectanguls(3 on each side) in the red area?
model manic, why is the shroud painted silver?
I believe those panels are lateral side scanning passive sonar.
After consulting a dictionary for the meaning of “shroud”, I know it’s the part covering the propeller. I think it was painted silver because the instructions tell so. What’s the correct color for this part?
same color as the top half of the sub which should cover the whole sub.
Thanks for your info. I’ll ask “Tazmanian” why he painted them silver then.
You might suggest he do some research into USN modern paint schemes if you plan on showcasing more of his work.
http://www.subcommittee.com/SubComm/member_homepages_search.cfm?MemberID=222
Look for SSN-21 and Carter Rollout photos. I’m sure the workman ship is there, but it just kinda makes some people smirk when they see that.
Actually Tracy, I’m not convinced the workmanship is there. Look at how bad out of plumb the schnorkel intake mast projection is. It also looks like he polished (or futured) the areas which were to receive the draft mark decals, then failed to flat over them. The whole hull has an uneven sheen.
MM your builders are rushing their work and delivering items to you which have problems. If I were paying good money, I wouldn’t accept some of the gack I see posted.
“gack”? That’s the sound my cat makes when she coughs up a hairball … usually where my feet can find it first thing in the morning [sigh]
I was just trying to throw him a bone Ed; he’s finished more models than I have this year, and when it comes down to is, which " looks worse," an unfinished kit, or a finished one with mistakes?
Tracy, MM is not a builder. He buys completed models, most that have been shown here on FSM appear to have problems to some extent or another
