USS Hornet/Battle of Midway
What color of paint/mfgr do I use to best replicate the wooden flight deck?
While the flight deck was wood, it was not wood colored. Hornet would have had her deck stained dark blue, specifically Norfolk No. 250N Blue Flight Deck Stain. I know that Testors Marine Acrylics line of paints and WEM’s enamel line of paints both have this color.
-Devin
Measure 12
Graded System
(Source: Ships-2 Rev. 1 September 1941)
Vertical Surfaces:
Vertical surfaces from boot-topping to level of main deck or highest sheer line, continuous for full length, on all vessels except carriers, Sea Blue 5-S.
On carriers, including Lexington and Saratoga, from waterline to level of hanger deck, Sea Blue, 5-S.
ay 5-O. Pole masts, yards, slender upper works above level of top superstructure masses, Haze Gray 5-H.
Horizontal Surfaces:
Horizontal surfaces, Deck Blue, 20-B.
Wood Decks.
Wood decks except on submarines and carriers shall be darkened to the color Deck Blue. Deck Blue paint shall be used in lieu of stain for this purpose.
Canvas Covers.
Canvas covers visible from the outside vessel are to be dyed a color corresponding to Deck Blue.
Notes:
The camouflage painting need not be exact or carried into corners. Small gear, wires, rigging, and areas permanently in shadow, as under boats, etc., need not be painted with the camouflage colors. There is no objection to exact or careful painting which may be desired for the sake of good appearance at close range.
All bright or shiny objects, no matter how insignificant, shall be painted, covered, or removed.
Glass windows shall be covered or removed, especially during the day in sunny weather, and at night when anticipating searchlight discovery. Insofar as conditions permit, similar precautions shall be taken on airport lenses.
While the SHIPS-2 citation is technically correct, by early 1941 the Pacific Fleet had dispensed with the use of 5-S Sea Blue, replacing it with 5-N Navy Blue. The darkest color on HORNET’s camouflage was 5-N, not 5-S. In addition, by the time of the Pearl Harbor attack, all the Navy’s carriers had stained their decks with Norfolk 250-N Flight Deck Stain (a very different color from 20-B Deck Blue). Norfolk 250-N remained in use until late 1941, when Flight Deck Stain 21 replaced it.
We have all the colors for HORNET accurately matched and available in our Colourcoats enamels.
Cheers,
John Snyder, White Ensign Models, http://WhiteEnsignModels.com
