I managed to drag the family along to Salem and a visit to the very fine Peabody Essex Museum (PEM) to have a firsthand look at the famous Hull model of Old Ironsides. For those not familiar with the model it was built by the crew of USS Constitution and presented to Isaac Hull when he quit the ship to attend to family matters shortly after his victory over HMS Guerriere. As such, it is rightly considered a primary contemporary representation of how she appeared when she first burst into glory. The white stripe and green bulwarks are two of the key elements to note. Some additional elements worthwhile for modelers to note:
Hatch coamings and deck furniture are also green
No gunport lids (except the two nearest the bow on either side to keep out the sea)
Six stern windows
Jacobs ladders at stern
Popular legend has it that Commodore Rodgers used it as a centerpiece at a grand dinner and actually fired a cannon on board… Probably a bunch of hooey. The model is perplexing in some ways… The basic hull is very carefully crafted, but the upper works are downright primitive… The gundeck looks carefully planked, but the spar deck is less detailed with wide planking strips. The carronades are not represented - only long guns on crude carriages with no wheels. No ship’s wheel or boats… Some think the crew left these out to acknowledge the wheel being shot away in battle and most of the boats damaged. Not sure that isn’t unfounded theory from an unaccredited source…(in fact, her wheel was shot away in the Java battle - not this one) Most likey the crew didn’t have time to add these (or the wheel was once there and has been lost over time) before they presented it to Hull. Interestingly the rigging is generally very fine, which adds to the mystery. There is a B&W photo in the navsource site showing the model some time back with a placard indicating British POWs repaired the model at some point. If true, I would wildly speculate that they tuned up the rigging.
There was a small study done on this model by a Swedish gentleman named Olof A. Eriksen who was building a massive stainless steel model of the great ship. He apparently gained access to the model through the good office of Commander Martin. Here is a link to his findings:
Essentially he theorizes that the model was begun as a careful project to pass some idle hours at sea by a reasonably skilled modeler seaman. After the battle the crew found out Hull was leaving and likely decided to gang up on the project to hurry it through to completion - hence the difference between the careful parts and the rushed elements. It is likely that the basic hull was completed and painted up to the gundeck before the rush was on… All of which is academic speculation, but his theory makes sense to me after seeing the model in person.
It sits off to the side in the original East India museum building and has no placard or other indication of its significance in the immediate vicinity:
There may be a small hole where a wheel may have once been:
Note the carefully seized lines and the worming/keckling on the anchor cable:
More photos at this link:
https://picasaweb.google.com/106997252788973852335/PEMUSSConstitutionHullModel
It is a remarkable artifact and well worth a visit if you’re ever in the neighborhood.
