USS Constitution bulwarks color
Gentlemen:
I am at a quandary at what are the proper color of the ships bulwarks. The ship as she is currently painted is sort of a dark teal green. But I was of the opinion that they were either red or white during the war of 1812.
I an about to start on the Revell 1/96 Constitution, and any help would be apperciated.
Thanks in advance
Dick:
The Isaac Hull model from 1812 has dark green bulwarks. Although the model is a bit crude in areas, it is a large scale model of the Constitution made by the crew for Captain Hull soon after the battle with the Guerriere and one would think they would know what the colors were on their own ship. So, I would say some shade of dark green for the 1812 configuration.
Russ
Russ:
Thanks for the information. I will be painting the main deck bulwarks a dark green. Howevwer, I will be painting the gun deck bulwarks white along with the underside of the main deck.
Again thanks for the information.
Dick:
That would work. The logbook says they white washed (probably slightly off white) the sides of the gun deck as well as the under side of the spar deck. I think that is what you meant when you said main deck right? The upper (also called weather) deck is the spar deck and then the next deck down is the gun deck.
Russ
So this brings up a question I have posed before … were the gun carriages red or what color were they ? Questions , questions… The bulwarks were green on the Constitution but that didn`t necessarily apply to the President or the United States, is that correct ?
Armchair:
The color of the gun carriages is unknown in 1812 is unknown. That is first and foremost.
Now, there I do recall a note in Naval Documents Relating to the Barbary Wars volume 5 pg 81 that says in 1804 they painted the guns yellow to correspond with the upper deck paint work. Given how often the log mentions blacking the guns, I have to think this yellow paint refers to the carriages and not the gun barrels.
Now, that was in 1804 and we know that by 1812, she had the green paint work on the upper deck bulwarks. So, perhaps they painted the carriages green in 1812 to correspond with her upper paint work the same way they painted them yellow in 1804. Not much help, I am afraid. If I could get a decent look at the 1812 Isaac Hull model, we could at least know how they painted those gun carriages.
As to your other question, there is nothing to say the other 44s were painted the same as Constitution. No doubt they all used what they had whenever they had it and they were painted according to their captain’s whims as the Navy Department had only just begun to try and regulate such things as naval paint work. By the 1820s, the color schemes for American naval ships was much more regulated than it had been during the War of 1812.
Russ
Hello all,
The following has been posted a couple of times before - If you’d like to dig up the other threads that it exists in, just search for the keywords “Ray Morton”. This info was posted a few years back on another modeling site, I don’t recall which.
Subject: Constitution-s Colors
The question often arises, How was Constitution painted? The
answers seem to be varied and they seldom seem to match primary
documentation. Here is what is known at this writing to me to be the
best color information for Constitution for only some of her
configurations and time periods:
In her early years, Constitution was always tarred below the four gun
strakes, probably until the 1906 overhaul. As-built in 1797 through
1811, she had yellow ochre (50:50 with white lead – still a
brownish-yellow but not as dull) gun strakes, gun tompions, gallery
trim, bowsprit, and lower masts as well as two pin stripes leading aft
along the hull from the head rails. The stern had a lampblack ground
with white lead, vermilion, medium-light blue, and light yellow ochre
trim. The ship-s name is not on the stern in 1812 (see Captain Hull-s
model of September 1812 at the Peabody Essex Museum in Salem,
Massachusetts). The weather rails were lampblack for all periods. ONLY
the four one-inch recessed gun strakes received the contrasting color –
NEVER a broad band of color that I have ever been able to document. The
gun strakes were white lead from 1811 through 1815 off and on with
yellow ochre (to include a change in the color of the quarter gallery
trim and, likely, the gun tompions) and were yellow ochre again from
1815 until the 1817 overhaul when the US Navy was changing to uniform
white lead gun strakes in almost all its ships, to include white lead
inner bulwarks and waterways from about 1817 as well.
From July 1844 through 14 May 1845, Constitution had a white lead hull
with vermilion gun strakes. In May 1845, she was repainted the white on
black color scheme. Her configuraton at that time was very close to the
Brandywine first class frigates, especially her bow treatment.
The gun port lids were always lampblack on all six surfaces (an
exception might have been the vermilion gun strake period, though I
doubt it). The gun deck gun port lids were NOT hinged until about the
American Civil War but, prior to that time, were completely removed and
sent below when exercising the gun deck guns – no gun port lids were
provided in the spar deck, ever. The gun deck gun port lids were split
in half horizontally in 1804 but were still NOT hinged, with some minor
exceptions to this up forward.
The Bowsprit and lower masts were woolded until 1809 and the woolding
was lampblack (rigging tarred). Until 1809 the fighting tops and the
doublings were lampblack. ALL of the yards were blackened (coal
tarred), just like the bends – to include the yard arms – as well as
the lower studding-sail booms, spanker boom, and gaff. After 1809, the
fighting tops (except for their railings and stanchions) and the
doublings were white lead. There was NO white at the mast heads/trucks.
The upper masts were left bright (actually oiled) so that their
remaining strength could be determined from their color. Since upper
masts were replaced often, they would each be a different color from
each of the other upper mast spars. The same is true for the jib boom
and the flying jib boom. Until 1809, Constitution had a single
lampblack martingale – and a white lead double dolphin striker after
  1. The doublings for the jib spars were lampblack until 1809 when
    they were painted white lead. The sails were also replaced and patched,
    as was the rigging, and none of these items would have been an overall
    same color nor exactly match any of their sister components.
    The rigging included hemp, hide, and flax cordage (plus horsehair in the
    limber) and was one-stranded through six-stranded, plus the
    nine-stranded cables and hawsers. Both left-handed and right-handed
    rope was used as well as water-laid and plain-laid. Some ropes were
    reverse-laid and others were slack-laid – at least one case combines
    both slack/reverse-laid. I know that this opens many rigging questions
    but the answers would be about 700 to 1000 pages long with a few hundred
    drawings. Constitution followed Brady-s Kedge Anchor, AMERICAN
    rigging practice, and NOT Lever, Steele, Biddlecomb, Lees, Lavry, et
    al., which describe BRITISH rigging practice.
    The decks exposed to the weather would have been grayed to a depth much
    beyond just surface discoloration – holy stoning would NOT normally
    have removed enough wood to make the decks white. The idea of holy
    stoning was to remove only the dirt and rigging tar from the deck – not
    the wood. The gun and spar decks were longleaf yellow pine, except
    under the guns where they were white oak. The two woods weather in
    color differently. The tarring of the deck paying was most likely dark
    chocolate brown and NOT black.
    After 1809, the upper studding-sail booms were lampblack (probably
    tar-blackened) from the tip of the yard arm outboard, when housed, and
    from the tip of the yardarm inboard, when extended. The in-between
    portion was white lead. Prior to 1809, the upper studding-sail booms
    appear to have been completely blackened. The spanker boom was white
    lead outboard the taffrail and black inboard after 1809 and all black
    before 1809 – the gaff was always black. After about 1809, a mizzen
    trysail (or snow) mast was installed, which was white lead.
    Gun carriages were terra cotta (the brownish boxcar red) except for
    1804-1809 when the carriages were yellow the color of butter with
    lampblack gun tubes, iron fittings, and trucks. After 1845, or so, many
    of the gun carriages were lampblack and all were most likely lampblack
    upon entering the American Civil War era and afterwards.
    Of the 500+ individual guns that have been in Constitution, of
    fifty-one different types, they were all smooth to the touch except for
    one type, which I have yet to see modeled. They had a modified varnish
    coating that produced a satin-gloss (satin for a model) that was
    pigmented with lampblack. The guns were normally given a fresh water
    wash each morning and then rubbed down with an oily rag. Tompions
    normally matched the gun strake color and were not embellished with
    gawdy stars, etc. Constitution was, and is, a warship – NOT a circus
    float…!
    The spar deck inner bulkhead (only a quarter deck and forecastle with an
    open waist until about 1804 or 1809 – no spar deck, per se, until that
    time) arguably was vermilion as well as the waterway (a red-orange
    scarlet color, just like the British used – but NEVER a red) as the
    gun sills are known to have been vermilion from 1797-1804. 1804-1809
    the sills appear to have been lampblack from then on and the inner
    bulkhead and waterway butter-yellow. After 1809, the inner bulkhead and
    waterway were dark green (about that of Humbrol #149, which needs to be
    scaled and weathered) still retaining the lampblack gun port sills.
    After 1817, the inner bulkhead and waterway were, most likely, white
    lead with lampblack gun port sills.
    Deck furniture was likely white lead, with bright pin rails, as-built –
    and butter-yellow or dark green to match the changes in the inner
    bulwark-s color changes between 1804 and 1817. I have not yet
    determined the deck furniture color after the 1817 overhaul from primary
    documentation. Belaying pins were iron and, if painted, would likely
    have been hot coal tarred.
    Ship-s small boats were overall white lead externally, except they were
    lampblack between about 1835 and 1845. The black paint did not work
    well at all on the ship-s small boats and was replaced with white lead
    about 1845 throughout the US Navy. The white boats typically had a
    single distinguishing color on the sheer strake. Ship-s small boat
    painting is, indeed, a very large subject area by itself.
    A good color approximation of the red and the blue in the wool ensigns,
    pennants, and flags for Constitution is: Humbrol #153 with a slight
    amount of Humbrol #73 wine added for the Madder Root Red and Humbrol
    #104 made a little lighter (with a touch of Humbrol #34 white) and a
    bit grayer for the Indigo Blue – until about World War One when
    bright synthetic dyestuffs started being used in US Navy flags. The
    white in flags was undyed white wool – an off-white color (a touch of
    Humbrol #71 linen in Humbrol #34 seems to work well). Other flag
    colors and flags for Constitution are much larger subjects.
    Try to avoid using straight black and straight white in a model – they
    are too stark for scale work and render a toy-like appearance. Use a
    very dark gray and an off-white (antique white), respectively.
    Don-t use the present real Constitution to determine the
    configuration, or painting, of the historic Constitution for ANY
    historic period, except 1932, 1960, 1976, or 1996, if then. Presently,
    the real Constitution is NOT in a War of 1812 configuration as federal
    law mandates – she-s slowly on her way towards such a configuration,
    assuming she quits stumbling over the non-1812 fantasized overhaul
    configuration of 1932.
Thanks j for the information. This shoule keep me bust for a few days.
Dick Wood
