USS Buchanan 1:350th NOOB
hi guys I just got this model and I want to do it justice. I bought the pe upgrade for it I am thinking of getting the other pe kit for it and putting the best of both on. I am totaly new at this and I want to turn out a great model so any tips and advise would be appreciated. thanks
Welcome to the dark side.
If you have never done model ship photoetch application, let me suggest that you stick with the PE which comes in the set plus the Dragon Buchanan upgrade. The photoetch set by Gold Medal Models is very nice, but it has much of the same items as are in the Dragon sets. It may be a bit finer and it will be easier to screw up. As a first ship model, believe me you will screw up. I still do.
I prefer to airbrush my PE while still on the fret while I am airbrushing the model. Apply the PE afterwards. It is easier to mask & paint first (IMO) than the otherway around. I generally do not need to prime my PE. It comes clean from the manufacturer. They have to clean it or it would continue to etch and you would have a baggie of not too much. You may want to give the PE a swish in lacquer thinner if you have been fondling it in your pizza-grease stained hands. I have likewise found that a soak in vinegar to give the part some ‘tooth’ is not necessary.
Rule 1: Measure twice, cut once. Use a pair of draftsmans dividers to measure between logical end points; previous rail runs, gun tubs, bulkheads, etc. Work in 2 to 3 inch lengths. Resist the urge to do the entire side in one piece just because you have a piece that long.
Use a #10 xacto blade on a piece of tile to cut the part fromt he fret. One finger on the part while cutting will help it from flying into oblivion. Use a sanding stick to smooth any nubbins. Plan on going back at the end on touching up any nicks in the paint.
Make your bends off the model. A Hold-n-Fold or Etchmate is not necessary. Bend between a pair of opposed razor blades, or a square-jawed pliers. Once you work through the sequence of bends necessary using a simple tool, it will make you more efficient with a more complex tool. [Remember just having the tool in your toolbox doesn’t make you a better modeler, you still need to know how to use it and to practice.]
Round bends can be made around drill bit shanks. Bend one size smaller since they will spring back.
I recommend a white glue, such as Aleenes Tacky Glue, from the craft store, to tack the part in place. It grabs quickly yet allows time to reposition. Best of all is that mistakes clean up with water. Put a pin-point sized dot of glue on each end and every 1/2 inch or so. Place, postion, and allow to dry. When dry go back with a fine bead of CA applied along the gutter rail to secure everything in place.
Work inside to out and top to bottom. This will minimize your disturbing previously installed work.
Once everything is in place go back and hand touch up any nicks or cracks in the paint. A final coat of clear flat will blend everything together and will kill the shine of the CA.
The Buchanan is a beautiful kit. Because it is like many Dragon armor kits, “why do something in 5 parts when 20 will do”, I tend to not recommend the kit to a raw ship NOOB, or one who doesn’t have a Dragon tank or two under his belt. My raw NOOB recommendations with PE are the Fletcher by Tamiya, the England by Trumpeter, or the Emden/Dresden by Revell.
You picked a nice kit to start with IMHO, but then I am a little biased. If you have not built many kits with PE, I would agree with Ed and say start on a simpler kit. It will make you appreciate the Buchanan even more. Besides the basic modeling tools you are going to need some really fine tweezers and good optics. Some of the detail parts on this kit are very small and hard to handle if you have 5 thumbs on each hand like I do. One thing I find helpful is to lay the sprue on a peice of masking tape sticky side up and cut the smaller parts off the sprue allowing the tape to help hold them.
Before you begin, get some history on the real ship. We have an ongoing thread on the ModelWarships.com forum in the Calling All Ship Fans (CASF) section. Also check the Picture Post section for some examples of Buchanan builds that other modelers have posted. The basic Buchanan kit can be readily built into 9 other ships with minimal modification. If you are intimidated by the MS. 12 mod camo, then consider the simple Ms-21 overall blue scheme she wore in 43. When you get started make sure you come back and post pictures of your build.
Is modelwarships.com down?
No but I did reboot the server yesterday. So we were offline for 30-40 minutes.
Ed has given you some excellent advice! You HAVE started off with a deceptively tricky model (it’s a small ship, it should be EASY!). If you find you are getting frustrated, then put the model down, try something else that is a bit simpler first to get your bearings (the Tamiya Fletcher, or the Tamiya Yukikaze are BOTH good choices!), and then return and proceed as per Ed’s instructions. You will get an outstanding model out of it!!
Well first off thanks for the advice it means allot. I dont think I would tackle this except Charles Landrum recomended it and hes local so if I have a tricky part I can ask him at a meeting or e-mail him. I learned a long time ago that small does not mean easy. I think with you guys and the guys in the local IPMS I should be ok. I am going to start building tomorrow so look for pics soon.
