USS Alabama in modified 12 camouflage
Well, mostly have the camouflage in place. I worked on the decks a bit this morning. Right now everything is just tacked together to see how the camouflage visually flows from the vertical hull to the superstructure. I think it is coming out OK, definitely challenging to get it all lined up. So far it is mostly airbrushed with a little bit of touch up. The next step is really to paint the hull (I sprayed on the boot top.) Will mask that off and spray the bottom. I am worried about how well the hull will join the upper verticals. Since the paint is more or less done, I wont be able to do a lot of fill work. It fits loosely together quite well so I am optimistic that any fill will be able to be done from the inside. If that goes OK, I will finally be able to get the decks down permanently and then work on the small details
Here is a (slightly) better photo of my progress so far. Follow the whole build on http://littleplasticparts.tumblr.com/
Need some bigger pictures, but looks good for a complicated scheme.
Yup,what he said!
I really need to learn how to use a camera
Maybe, but she looks really nice.
