Hi I have a revell kenworth kit and need a solution to getting the same shine that the chrome has,I have glued the fuel tanks and the exhaust stacks and sanded the joins down removing the chrome.any help most appreciated.
You can use Bare Metal Foil over te sanded areas, just make sure you sand the areas as smooth as possible.
I use Alclad. Both their chrome and polished aluminum colors make a good chrome look. The secrets to using it are to have a flawless gloss black undercoat, and airbrush it on in a very thin coat.
Al-Clad Chrome will be a good option. High gloss perfect surface with a coat of high gloss black and a light coat of Al-Clad chrome
i did the same as you on motorcycle exhaust system and the painted it with Al - Clad and it looks like this
Try painting some Tamiya clear smoke over the chrome.
Its a quick, easy, cheap method.
If you don’t like it you can still go with the methods above.
hi,thanks for the replies, i might try the foil. sorry for not getting back to you all sooner,busy with the work thing.
Okay ;
I give . But what happens if you want to polish it say a year from now ? No one has mentioned that ! T.B.
Use Alclad. You’ll never use anything else.
