using bare metal foil.
Hi.I was just wondering,when using bare metal foil, will the overlaping seams be visible?
The stuff is pretty thin but you will be able to see where the 2 pieces overlap - just
You’ll want to join peices at a panel line. You can overlap both peices and then cut with the panel line.
Andy
Yep what he said. If that is not possible try to make joints in a less noticable place.
[#ditto] What they said, plus, keep a SHARP blade in your xacto, or it will tear the foil and you’ll be upset, to say the least!
Brian [C):-)]
