I have the Trump N. Carolina kit and Lion Roar detail set on order and have begun researching the fits and finishes of the ship. I have decided to model her in her 1944 configuration but apparantly there has been a great deal of confusion regarding the camouflage scheme worn by the ship in 1944. Most seem to agree that she wore the Measure 32 Pattern System, however, here is where the controversy starts. The official composition of Ms. 32 is a pattern of Light Grey, Ocean Grey and Black on vertical surfaces with Deck Blue and Ocean Grey on all horizontal surfaces. However, according to the 2000 book U.S.S. North Carolina TR 1, by Randall Shoker - who is involved in the running of the N. Carolina Museum - and others, the ship was painted in a combination of Pale Grey, Haze Grey and Navy Blue.
I checked the ShipCamouflage website and found that a very lively (and progressively nasty) debate raged on the forums there about a year ago when the kit was first released. Unfortunately, a concensus was never reached (if thats even possible).
I’m by no means a rivet counter, but since I’m making a such a large investment both time and money wise in this project I want to make sure that I am being as accurate as I can be. My gut instinct is to go by the Bureau of Ships guidelines, but I am just checking to see if anything more definative has been determined in the last year. In addition, since the measure calls for both Deck Blue and Ocean Grey on all horizontal surfaces, were there specific rules on which surfaces were which color or were the colors put down in a pattern specific to the North Carolina?
Any assistance on this subject will be greatly appreciated.
If you’re doing her post September 1944 then you can use the Trumpy kit and Lion Roar PE as they are (kit would need surgery otherwise and the LR PE only has the post Sept. 1944 radar suite). In that case use 5-L, 5-O and black, don’t let the secondary source buffoons snow you, until they bother to do real research with original source materials they are just repeating errors or blowing smoke (hint, I have close to 1000 hours of research time on this one ship). Mr. Shoker and I have discussed this at length, he’s now leaning towards the colors I just listed. Realize there are no color photos of her later Ms32/18d scheme that have been found at NARA or NHC so the buffoons base all their color arguments on B&W photos and publications with many easy to spot errors. Until the museum lets a third party sand the paint back to bare metal and color match every layer there will never be a 100% sure answer.
As to her decks in that version of the scheme, overall deck blue by the time she rejoins the fleet. For a brief while she has the remains of the previous colors on her turret tops but that’s while she’s still working up from the refit. Be aware the turrets that carry the black all around the top appear to have black roofs as well. Do not go by the design sheet for the pattern use photos (if the lower starboard bow panel is grey and she has the bowl shaped SK-2 radar you have the right ones). For this version use masking tape, for the previous version you have to cut a bunch of wiggles and paint brush boogies into the edges.
BTW that shipcamouflage thread got nasty because one person (Warneke) doesn’t like to be held to his own “rules of proof”…he can’t put up and won’t shut up.
Ron, thanks very much for the info, but your answer leads me to additional questions. First, the only reference I currently have is the Shoker TR 1 book. Aside from the colors listed there are the patterns in the color plates accurate? If not, are there drawings available showing the proper pattern? Secondly, when you say that the turrets should have black roofs are you refering to the 5" turrets?
The pattern in Shoker’s book is close enough to correct for the Septmeber 1944 and later time frame (note it cannot be used for the September 1943-August 1944 pattern, there were differences). I say close enough because one of the “colors” on the pattern on page 51 is slightly out if register. I still recommend looking at some photos, especially for the main battery turrets. From what I’ve seen the rangefinder ears on the main battery turrets carry the predominant side color onto their tops. As for the black turrets, yes the 5" secondaries.
Sorry Ron, another question. In the photo below it appears that the roof of the aft 16" turret was not painted in Deck Blue but in the Light Grey of its other sides. Am I reading the photo right or is it the lighter colored equipment located there creating the illusion that the roof is the same color?
It sure looks light grey in the photos I have too. BTW- go ahead and start the thing because you have a lot of puttying and sanding to do before applying PE.
Those of you interested in the USS North Carolina may want to know that the Summer issue of Nautical Research Journal, published by the Nautical Research Guild, will have an in depth myth busting article on the ship. You can go to www.naut-res-guild.org to subscribe to the Journal.
Yes I wrote the article and it is the one place you’ll be able to find accurate information from original source douments on this ship…at least for now.
