Tutorial Idea: Spare Track
I’d love for someone to show me how to make spare track look realistic. Thanks.
…and all the other examples that I don’t have time to find/cut/paste, that I like so well.
ps1scw,
The way I do it is pretty straightforward, I base coat with Testor’s Nonbuffing Metalizer Gunmetal, then lightly dry-brush with Steel, then apply a 90/10 Thinner/Rust wash very carefully so as not to lift up the Metalizer. As that dries, it interacts with the Metalizer particles and creates a nice rusty finish that isn’t too orangeish. Then I dry-brush Burnt Umber and voila, spare tracks. I just did this today in fact with the Jagdtiger.
I basecoat the tracks in either an extremely dark gunmetal, or a basecoat of Testors enamel rust, depending on the level of rusting I want to show. After that, I will apply a mixture of rust and dark brown shades of pigments and pastels. I will seal it with thinner, and allow to fully dry, then remove most of it with a stiff brush. Thereafter, I will VERY lightly drybrush the parts with a light silver, and then once again apply the pigmens, this time leaving them loose.
How I did mine is as follows: I painted the tracks dark grey for the base coat. Then a heavy dry brussh of steel was used. Followed by a wash of burnt umber (oil based). I then used MIG pigments. The pigments used were standard rust and black. I blended the pigments till I found what I liked. If it is to much just use turpentine to soften the effect and you can then redo after the turpentine is dry. I made plenty of mistakes and learned from them and help from the forum here helpeds me continue to improve.
Here’s my approach that was used for the spare links in your second picture.
A spare link, since it hasn’t been “in action”, will be more weathered. That usually means more tarnished (a darker color) and a bit more corroded or rusted than the tracks. I start with the track link that has been painted with the base coat of the main tracks. I darken the base coat color a shade or two and dry brush the spare links. Not completely re-painting the link but adding the darker shade in an irregular pattern to the base coat. Then with a soft brush, add some Mig pigments standard rust (P025). With a stiffer bristled brush, blend and wipe away the pigment until you get the desired rust effect, then fix with mineral spirits. The spirits will dampen the pigment color, so don’t be afraid of going a bit more with the pigments initially. If you want, you can dry brush a metallic paint to add highlights. That’s it.
Good one! and perfect timing as I am about to do exactly that (paint spare tracks). Thanks again for the info!
Take a look at this one.
http://ausfwerks.com//techniques/spare/main.html
HTH
