I seem to suffer from A.D.D. as I was suddenly motivated to drag out this kit to address the floppy fuselage. For those unfamiliar with the kit, Trumpeter decided to mold the fuselage halves in left/right pieces, but failed to provide any bulkheads to keep the centerline from sagging. An aftermarket plywood brace is available, but I thought that making a simple spine from plastic would solve the problem.
https://flic.kr/p/EL2w85][/url]Vigilante-05 by N.T. Izumi, on Flickr
Rather than spend time making precise measurements, I made it so that pieces of “T” and “C” channel strips could just be cut and fit as needed to get the desired result.
https://flic.kr/p/EfSEa3][/url]Vigilante-02 by N.T. Izumi, on Flickr
https://flic.kr/p/F5caFM][/url]Vigilante-03 by N.T. Izumi, on Flickr
https://flic.kr/p/Ege2UV][/url]Vigilante-04 by N.T. Izumi, on Flickr
Seems to work! Of course, the saggy fuselage joint is only one of the many serious shortcomings of this much maligned kit, so I have some questions for those that know:
For the intakes (or more correctly the lack thereof), what do the FOD covers look like? I am not too inclined to vac form the super-long intake tunnels, as they would be really hard to filll, sand, and paint white. I know Cutting Edge made a resin set, but it it OOP and I want to keep this build simple and cheap.
I had read that the inboard leading edges of the intakes had a different profile on certain production blocks. Can someone shed light on this? Also, was the LERX on the kit also something associated with certain blocks?
The kit comes with two kinds of nukes (!) to hang under the wings, but what was the typical misison loadout during Vietnam? (Yes I know they didn’t carry nukes.) Were drop tanks common? Or did the aircraft fly combat missions clean, without tanks or pylons?
The RA-5C’s primary mission was recon, but I guess the “A” in its designation meant that it retained (but did not use) its strike capability. So is the HUD still appropriate? Or was it used for general flight information as well?
Inquiring minds want to know. (A.D.D. ones too!) TIA.
