Trouble with post number 1
Trouble navigating the posting of my Welcome message. Tried three days and it kept going round and around never once showing my full welcome message. Finally it asked what do you want to do with the post and the only options were to keep on editing, which I thought i was done, or delete. Finally after too many efforts I pushed delete. Began rewriting and was cut off before the main part of the story came up in the write up. So Post 1 is only a partial. Frustrated.
There looks to be a format issue of some kind on your first post. I’ve seen it here before but don’t remember what the cause was determined to be, nor how to fix it. This post looks like it worked properly. Welcome to the forums, there are occasional issues and sometimes lagginess, but it’s pretty good usually.
You could reach out to Tim Kidwell (Tim_Kidwell1) ask him to look at the post or refer it to the support resources.
Wolf78, I’m not sure if you typed your post in a different word processor and then copied it over or if you typed it directly into the forum. Either way, you had tabbed indents, which can cause a change in formatting. When making paragraphs in the forum it’s better to use two hard returns.
Like this.
It’s easier to read online, and it keeps the formatting clear. I went back and cleaned up that initial post so the formatting should be all good.
