trimming parts from "trees" ... your method ???
Hi fellow modelers …
As I sit here at my work bench, on a cold and snowy Saturday … working on my current project, an F/A-18 HORNET for the Community Building Project (see thread under General Modeling) … I was thinking about the various ways of trimming parts from the “tree”.
One of the rules for the CBP is that we can use a limited list of tools to build our project. Sprue nippers, sprue cutters, whatever you call them … are not on the list … we can use our “xacto” knife … this got me to thinking … what are other builders methods of trimming parts ??? [^]
Gee, seems like I/we have come along way from the early days … I used to use an old, kinda rusty, very dull pocket knife with a yellow handle … hmmm wonder what ever happened to that old knife … oh,well …
How do you prefer to trim parts off their “trees” ???
As I sit by my computer on a nice sunny 70 degree day, I used to use an old set of nail clips to cut parts from the tree. I still have them in my tools bin and come across the every so often. The good old day.
Berny
As I sit here on a…no…that’s enough weather forcasts for one day…LOL.
I use a small set of side cutters that I picked up at a five and dime many years ago…works very well…in most cases.
Really depends on the kit and the size of the sprue attatchments.
Usually I use a set of sidecutters I picked up at a local department store.
I found some small thin saw blades that fit into the chuck of my number 1 exacto knife handle. I’m not certain what their blade number is, but they’ve often saved the day for me when I had a small part with a big sprue attatchement and the side cutters would have been too big and clumsy for the job.
I’m a BROKE student and can’t afford any fancy tools. use the X-Acto #11 and save the rest of my money for tuition
Maybe I’m old fashioned, but I’ve never lost a piece off the tree or ruined a part when cutting. I also remove any flash or seam lines while I’m at it!
As far as I can tell I don’t see an advantage to sprue cutters…perhaps someone can enlighten me on the benefits of a cutter and perhaps I’ll fork out the money! Until then I will stick with my trusty X-acto knife and beer.
… for James Mark:
I think you have it right … rely on your trusty xacto knife and beer!
A fellow can sure make things too complicated, building model kits shouldn’t be too complicated.
Go to Radio Shack in the 64 series try these bad boys only $3.99. I’ve always used them.
http://www.radioshack.com/images/ProductCatalog/ProductImage/64/64-1833.jpg
I use those fancy aviation sheers. They do a great job because you can cut flush to your piece without damaging it. But before that I used one of those big toe nail clippers. It worked well.
even cutting flush with a side colour can sometimes mar the surface. I usually cut a little bit away from the piece, then trim the remainder off.
I’ve got the same trimmer that Big Jake noted above. Cheap cutters that do a good job. I’ve found they come in really handy on ‘glass’ parts. Whenever I cut glass pieces off of the sprue, I tend to ‘stress’ the joint and sometimes it damages the piece. Even when I use the xacto blade I get some form of stress in the part (especially windshields). Using the trimmers, I cut well away from the part and then just ‘nip’ away at it until it is flush with the edge of the part. Works good for me.
M.
