Tree Holders and Such.
Hey Group,
I finally finnished my spray booth and it looks and works great. I do have a couple of things I did notice however that perhaps you can share your anwsers on?
Apparently at 15-20 psi dialed in on the compressor this will indeed blow your parts all over the booth.
Question: What devices do you have in place to better secure the part tree’s?
[:I]
I have shaped a hanger to hold the body off the ground to ensure I get the lower body panels when airbrushing. Do you have any other suggestions that may work in this regard?
Anyway, I am having a blast (and so are my part tree’s).
Please share your ideas.
Thanks a bunch.
You could use wooden spring type clothes pins. The jaws can be modified to what ever you want and then can be screwed to a block of wood, etc and set inside the spray booth when you need it. The clothes pins will keep those trees from flying unless of course you have a tornado [:D]
Here is what I use,
Go to radio shack and buy a pack of large “A” clamps, use a 1/4" round wooden dowel and make them about a 12" long. Put one end of the dowel into the rear of the clamp and using pliers pinch the end of the clamp to hold the dowel in place, I made mine up about 10 years ago they are still going strong. Here is the best part, put up a small piece of peg board on the wall with a 2" spacer so that the peg board stands away from the wall and you now have an instant parts holder. Check out pictures of my Work/Model bulding shop at the following link.
http://www.naplak.com/modeling/Modelers/workspaces.htm
Big Jake
Some of the upper scale electronics shops carry what is more or less a soldiering helper. Its a heavy based holder with two “roach clips” on independent arms that each have 2 elbows . I like that it has two, one some times isnt enough and the spruce will flop around a bit.
Some models even carry a magnifying glass for "detail " work.
