Does any one know where to find Treadway bridge sections? I am in the planning stage to do the gatehouse bridge at Funchilin Pass during the Chosin “attack in a different direction” march. With the availability now of Miniart’s Cats from Squadron, all I need now is 4 bridge sections, and a jeep. A Brockway would be nice for another direction if one is available from somewhere.
Bronco does a Bailey Bridge in 1/35. There is an old Revell/Renwall AVLB kit out there, I think based off a M48. I don’t know if either of these will fit your needs…
Sorry, but Baileys are totally different from a Treadway. TW’s are more portable bridge sections. Fort Wainwright still has a Bailey in active use for non-tactical traffic. I have seen them from Google searches, but haven’t found a supplier yet as both Sprue and Squadron don’t have them. Might have to try Hannants.
Ok, I did an image search to have a look see. Verlinden makes some with or without pontoons.
You don’t say what scale you are looking for.
I’ve the Verlinden Treadways with & without the rubber boaty things, in 1/35th,good, but solid, also available in 1/72nd.
HDS on Shapeways has the 1/35th Bridge Section, worth a look
In 1/35thScalelink have the vehicle and all the bridge parts…
or the base vehicle could be converted from HobbyBoss White 666 truck
Brockway 666 in 1/48th by Gaso.line maybe bridge bits, have a look
Wespe Models have various tricks is several scales
good luck
