After looking at the fine Gold Medal Models brass set for Hasegawa’s 1/350th scale Mikasa,I’m going to install the brass catwalks for the torpedo nets and I’d like to install the nets,too,but I’m not sure what kind or size of mesh to use. Any good advice?
Hi Flyguy,
We make a set of torpedo nets for the 1/350 battleship Konig which you might adapt for your Mikasa. However, they are designed for waterline only, not full-hull. Order item PE 3520.
Cheers,
John Snyder, White Ensign Models, http://WhiteEnsignModels.com
