Tiger buffs
Well my question is this I am building the taimya late pro. tiger 1 and want to know what the box is up front next to the drivers hatch is theinstuctions say to paint it buff so I did and it looks wrong I have pictures showing this box but of coarse they are b/w and not to clear…
thanks
ron
Ron -
Its a jack block. A block of wood reinforced with metal straps at each end and in the middle. Paint it natural wood and the straps metallic gray or tne hull color of yuor Tiger.
Post some pics when you get it done. Happy modeling,
Mark
Or, replace it with a chunk of real wood detailed with some lead foil straps.
i agree it is the jack box as well. you can also paint it red brown or a dark earth color. most units just painted it with the hull color anyway.
There are many ways to paint it. It depends on how worn you want the Tiger to be. The crews didn’t waste time with removing loose objects before painting, so if its a newly painted Tiger it would be the same color as the hull, the more worn the tank, the more paint would be worn of the jack block.
I figured that i did have it the hull color and painted it buff after alot of thinking and i am gonna repaint it the hull color thanks and i might even use real wood never thought of that and thanks again.
Yeah, the Aber “Super Tiger Set” has a little piece of wood in it for the block. They used balsa, but I think I’d use a different wood to get a different grain. Good luck.
