Hello everyone! Hope you all are in good health. I have recently discovered a technique by Andy’s Hobby Headquarters on how to easily thin Tamiya acrylic paints. Andy (at least that is what I think his name is) suggests that if you have a new, unused bottle of Tamiya paint, you can put in Tamiya’s acrylic thinner right into the pot until the liquid mixture reaches a certain notch inside the pot. I thought, well, this would make thinning really easy when I airbrush!
However, in his explanation, he used the regular size bottle. I was wondering if anyone knows whether or not this technique also works with Tamiya Color Acrylic Paint Mini.
Also, in addition, I was wondering if just straight up 99% isopropyl alcohol would also work and create the same result.
This is the link to his tutorial:
https://youtu.be/CQsXFl3yLho?t=221
Any help is appreciated! God bless!
You would be wasting an awful lot of paint using that method if you don’t use the whole bottle. Thinned paint does not keep well.
It’s extremely easy to thin Tamiya acrylics to a 1% milk consistency in a clean empty bottle with the exact amount one needs. I would always use their X-20 thinner. With the extremely high price of models in 2020 why risk using an inferior thinner?
I don’t understand why people want to attempt to reinvent the wheel. Andy is paying wholesale for the paint he is using, unlike the rest of us.
WilberWright is correct, thinned paint has a much shorter shelf life.
If your in a position to thin as Andy does, I have seen that pod cast and thought…now why didn’t I think of that?..then give it a shot. Seems and appears logical. However if your only gonna shoot a couple tiny pieces I would recommend thinning out of original container.
Thanks! I didn’t know that before, about the shelf life. I will keep that in mind.
I have a prethinned jar of Tamiya flat black because I use it a lot. It’s thinned with 91% alcohol. I just stir it before use and it works fine. I don’t see why their own X-20 won’t work too.
I’ve never seen a bottle of Tamiya paint go bad. Had some bottles for almost 30 years…
Testor’s enamels on the other hand… sometimes you’re lucky to get 1 year out of a bottle…
