Bob Stamp -
So many airbrushing variables to consider:
Paint type, gloss or flat.
Color or clear.
Airbrush needle/nozzle size.
Solid or camo.
Air pressure.
As you describe yourself as new to airbrushing, there will be a bit of experience and experimenting needed, before you reach a comfort level with what the start of the painting process is. Once basically familiar with what works for you, you’ll find not much ingredient adjustment is needed in final preparation.
I use Tamiya almost exclusively, I tried their X-20A and lacqeur thinner at first, then went to IPA, either 71 or 91% works fine, store bought LT also does well but seems to be a bit more aggressive and unpleasant for my use. It makes a great cleaner though.
Since you’ll be in a small space and have no fume control I solidly recommend IPA, it’s an effective cleaner as well for Tamiya, just not as quick as LT. When spraying anything, respiratory protection is a great assist.
My Tamiya most frequent thinning ratio, (just my own from experience, NO science involved,) 50 - 60% paint to IPA, sometimes as high as 90% IPA. As mentioned, with time and use you will have a beginning point in mind before you start the job.
For checking my paint flow and pressure when I begin a session I use glossy printed cardboard, such as the sort that holds products from the store. It replicates plastic bits better than plain cardboard, which absorbs the solution quickly and you can’t visualize the sprayed paint flow.
My usual pressure setting is 14-16 psi, rarely as high as 20 psi. The usual needle/nozzle size is medium, using Iwata and Badger equipment. In fairness I do seldom get some buildup on the needle, but then about every 10 or 15 passes I use a Q-Tip and IPA for a quick swipe of the tip. Tip dry is pretty much a non issue for me.
Best of luck as you get your airbrushing up to speed, you’ll soon have a very satifying time in the hobby. Above all do what works best for you, what works for me may be altogether wrong for you.
Patrick
