This is the tenth update on my basic landscape build for my diorama and showing some of the modeling of the various German communication devices I am preparing for the Bunker, as well as its furniture.
From this onwards I will be rather busy with placing them all into the Bunker and of course further detailing it with cabling, antennas and its power generators as well as placing all the hooks on the poles which will hold the camouflage net in place.
Following this I will start building and painting all the planned vehicles crowding various spaces and placing appropriate decals unto them.
Finally, I will start assembling and painting all the figures and decal them as well.
Once done with all that, I will finally start to plant vegetation all over the diorama, or as it is more commonly known in the modeling community, start flocking it.
Updates to all this will come to you as soon as one batch is completely finished, so please, do not hold it against me if I may appear somewhat absent from this space for a while.
it is not ill will but rather lots to work still facing me, but I promise you to peak occasionally in to see the progress of your own work in progress or finished.
I will also try to promptly answer your comments and questions you may have, but please give me the time to do so and don’t be offended if I should delay my answers to you. It only will mean that I am hard at work with my stuff and not that I am ignoring you by any means.
So, until I will have something new to report, this will be the last post on this subject.
OK then, here is part ten of my progress so far. Enjoy!
What you see here is a series of pictures of the Parking Lot being finally finished and some scenic sand applied a little bit everywhere and fixed with my own scenic cement concoction.
And this is a series of pictures of the Communication devices I have either built or still building and trying to paint as best as my clumsy hands and my weak eyesight manage to do it in such a microscopic scale. Some still require to be further refined and some of the folding tables will have to be given a a shiny appearance since they are metallic in nature, hence a touch of satin varnish unto them will be the solution.
On one of these pictures you will see my pointing finger to indicate the size of these darned things…
On the upper left side of this next picture you will notice a portable field telephone still waiting to be assembled. The instructions specified to paint it in plain Wood Color, but on the real thing I have spotted on many actual items it looked different, since the so called Wood color was actually a Reddish Brown with a marbled Black paint superimposed upon the superstructure.
I attempted to duplicate this effect in scale with watered down flat Black applied on the fresh Wooden color, but as you can see it didn’t come out as I had wished it to, but at this scale you would barely see the difference. Pity, I wished there were a better method to this.
Even this Light Gray Quadrant resulted into a messy paint job trying to place some Black knobs in the right places.
And this is the actual box containing the field telephone which was made of the very same material as the telephone itself: Bakelite. Not in metal and not in Wood as many claim it to have been. The Black marbled spots should be by far tinier than this, but even with 00000 sized brush one cannot reproduce it correctly.
This is another completely botched attempt to apply knobs and gauges to this quadrant. It will have to be refined and corrected.
The rest was rather easy to paint. I simply used a Medium Gray mad out of Vallejo’s own Flat Black and Flat White mixed with Vallejo’s German Tanker Feldgrau II from Panzer Aces #335
Which replicated the actual late Field Gray Germans used to paint their equipment, including the tables on which they were placed.
Please note that what you see here, is a mixture of Eduard (color printed PE), Verlinden (Resin) and Dragon (Styrene) equipment.
The Eduard ones were Early to Mid-War models still used to the end of the war therefore the contrast in colors.
They all still need to have cables connected to them which either serve to connect with each other, to a power generator, to a microphone, headset or a telephone. All this will come later and will be a bit fiddly to do.
See you soon for more…
