Sorry for the delay in getting an update.
i had gotten some work done, but suffered delays in getting the pictures ready.
then my emails w/ the pics were not getting thru to Moses.
nevertheless, here we are:
Monday night i painted the metal part of the road wheels Tamiya XF-53 (Neutral Grey).
i had read in another thread that the XF-63 (German Grey) seemed too dark, so i went with this lighter shade.
i took Frosty’s advice and used the circle template to mask the rubber parts of the wheels.
results varied. at several points i wondered if the rims were some metric size as the choices i had on my template were:
‘a little to big’ and ‘just a bit too small’.
i tried both, and eventually settled on the slightly oversized one.
i figured i could touch up w/ a brush later.
each wheel was mounted on a piece of sprue. i painted the backs first, dropping the template over the sprue and painting around it.
later, i determined that it would be easier to pull the sprue out, paint the back, and push it back in. then i would not have to paint around it.
once the back was done, i stuck the sprue into a foam block, held the mask over the front and sprayed that side. i tried it w/ the wheel vertical and horizontal. neither was ‘easier’ than the other for me.
then the wheel went onto another foam block to dry and the next one was started. i wiped the template now and then, but did not clean it w/ thinner as i was afraid of the thinner getting onto the black paint.
(because i knew i would be trying to go too fast for it to be all wiped off!)
when that was done, i returned to gluing bits together for the tank.
while getting ready to glue the top pieces on the ‘eyes’ on the front of the hull, i determined some nitwit had glued them on rotated 90 degrees! [B)] i rechecked the instructions and the box top picture. the instructions were inconclusive and i blame them! [}:)] but the boxtop was rather convincing. i was able to slide the exacto blade under the pieces and cut them free. i cleaned up the backs and the hull w/ sanding sticks and put them back on in what i hope is the proper orientation.
before i started that job, i had removed a piece from the sprue to attach to the left rear fender. it looks like a little license plate holder. the back has a serious ejector pin mark on it, so i filled it w/ CA. once i was done mucking about w/ the ‘eyes’ on the front of the hull, the ‘license plate’ was nowhere to be found! [:(!] a careful search of the floor yielded the missing road wheel hub from day 1, but no ‘license plate’. recalling the CA on the back, i checked everything else on the table it might have glued itself to, plus my forearms, feet, and most of the stuff in between. it looks like i will be making a replacement piece from sheet styrene. (THEN it will turn up!)
is there a rule in armor modeling that at least one piece must be ‘missing’ at all times? i will have to be more careful and not jump from task to task so much. and maybe not try to do everything in the same square foot of a 40" x 30" table!
here are some pics of the upper and lower hull separate, and mocked up. feel free to comment, but i doubt the pictures are clear enough for you to pick out too much! [:(] i GOTTA get a better camera. but borrowers cannot be choosers i guess.
see the roadwheels lurking in the distance?
thanks for all your help!
ed.
