I know this is gonna look like a lot of questions but it really isn’t. OK… so a German tank is nearing completion at the factory and moving down the line. Time for paint and zim. Red primer first, then the zim, then the camo? Would that be the correct order? And what color is zim itself? What would be seen if the is some zim that has battle damage? If it takes a hit from a 37MM say, I am guessing (no, really… I am guessing) that the zim is gonna chip, or chunk, off. Down to the bare metal or will the primer show through?
Zimmerit contained 15% Yellow Ochre pigment by weight, so it’s color was very similar to that of the Dunklegelb paint that covered it, only a bit lighter in tint. You are correct in the order of Red Oxide Primer, zimmerit, then camo paint. Depending on the size and depth of an impact, zimmerit would break off in chunks, exposing the Red Oxide Primer underneath. Obviously, if the hit was of a large caliber, it would expose bare metal too.
Thnaks for confirming what seemed the most loigcal… and foir the zim color info. That makes it easier[;)]
If you Google “Zimmerit” for images, you’ll find a few color shots of tanks with old Zimmerit exposed on their hulls, sort of a light yellow-gray color. I doubt it changes that much in color with age, as Yellow Ochre is a stable mineral pigment.
What about the field applied zim ?
When the zim chipped, do they also took of the paint and reveal the primer ?
Ben
Field-appled zimm, if chipped off, would show the paint that was on the tank prior to the field zimm being applied…
