testor airbrush question
I dug through my modeling stuff to produce some testor airbrush that appears to be dirty. I was wondering waht the process to clean it would be. It doesn’t appear as though the needles come off, it has a swivel thing to change the spray pattern (i think). I sprayed straight mineral spirits through it in order to attempt to get it working again. Anything else I need to do? It is one of the ones that hooks up to the air cans. If I keep going with this I’ll get myself a compressor eventually. Also what is the paint to thinner ratio, and is mineral spirits ok to use as the thinner or do i need something special?
Not sure about exactly which airbrush you have, but if the thing is spraying and there’s no paint build up on it, it should be fine. Mineral spirits is fine for enamel. If you recycle your cleanining thinner, a can of Kleen Strip mineral spirits form Home Depot will last years.
There are not hard rules for paint/thinner ratios. Even within the same brand and color, you will find bottle to bottle variations. Usually 3:1 or 2:1 is good place to start. The usual rule of thumb is to try an get it to the consistecy of 2% milk. After a bit of practice, you’ll get the hang of it. Do test spraying before spraying on your model, and always test spray on something non-porous like a plastic milk jug so that the paint will react as it would when being applied to the model.
