Tankers,Where do you get them? in 1/350 and such?
Okay, I give Up!
Guys and Ladies I have a problem. I want to build a support fleet for a “Bird Farm”
So there are two types of Oilers I need . a Tanker for the ship’s appetite and another for Avgas! You see there’s a problem with all my tankers. They are 1/160 or 1/87 in scale. yeah, Big !
I have all types Except any that served in the Navy in the wars or after. The only Collier I have ( Yeah the Navy burned coal too ) is in paper and it’s 1/325 ! So converting it won’t help.
It’s like freight carriers. You Can find the U.S.S. John Brown and other " Liberties" but where’s the Victories? The Revell Haskell and others can be modified sure enough, still doesn’t solve the problem.
Oh, the " Bird Farm " will be the U.S.S. Midway. I have the Gearings both in WW2 fit and the Fram Versions. I also have a " Turner Joy ."( The Newest Ship in our group.) I believe she was what they called then a "destroyer leader ". Sure didn’t look anything like us. We bristled with guns ( Before Fram) and she had these weird round topped singles and not very many either!
Her, ( the Turner Joy ) had almost what was called a Yacht Sheer. The Curve fore and aft of the deck. Shoot, with a bone in her teeth she looked downright mean, in a sparse sort of way.
But back to tankers, Will I have to do my battle group in the varied scales that Revell put out? I really don’t want to do it in 1/700. I can’t see those well enough to bother.
Now remember this. In a previous post I mentioned I have a severe allergy to resin dust . If I build anything in that, it’s full breathing gear and a tyvek Moonsuit !
So Styrene is best. thanks Much T.B.
I assume your Midway is post SCB-110. What kit will that be?
Otherwise, straight deck Revell, at 1/540.
In which case the Lindberg Kennebec class fleet oiler will serve well. The claim is that the scale is 1/520. One of our forum mates recently built the Round2 reissue.
i have about 4 of those Lindberg oilers with 1 built as is, 2 being kitbashed into 2 different classes of oilers & the 4th waiting to be kitbashed into a ww2 Cimarron Class Fleet Oiler.
http://www.modelerjoe.net/shipmodellist.html#LindOiler
So you want something in a bigger scale than the Lindberg kit.
You didn’t mention the Revell Mission Capistrano/ J.L Hanna, so I’m guessing that is already a part of your solution. It seems to me that a couple of them could be worked together to get a jumbo-ized T-3 like Passumpsic as modified in the 1960’s. (Just suggesting that makes me want to break out of my normal 1/700 world and give it a try)
Also, Heller made a 1/400 kit of the French tanker sisters La Seine and La Saone. Those ships were smaller than the USN fleet tankers, and might be sectioned a bit more to represent a Patapsco class AOG.
Best of luck
Rick
BlueJacket Ship Crafters has a T2 world War II era tanker at 1/16th scale, that can be either converted for navy service, or commercial civilan use after the war.
Happy modeling Crackers [:D]
I have a similar plan. I will build a task force of one carrier, one battleship, one heavy cruiser, one light cruser, two destroyers, one T2 tanker and one submarine. All in 1/350 scale
The T2 will be made from scatch in styrene and maybe wood, using plans I found on-line.
Sigep Ziggy:
Are you going to do Waterline or Full Hulls on yours? I have decided on Waterline with a refuel op going on in Moderate seas. Tin Can on one side and Carrier on the other. This will probably be my last Diorama too. T.B.
Oh, " G " ;
It has to be with the first type and arrangement of the Angle deck. Somewhere around 61-62.
TB
I will be building all full hull to be displayed on stands, however, I have played with the idea of a diorama which, being from Idaho, the T2 tanker Idaho Falls refueling the USS Idaho to port and the USS Boise to starboard.
Ziggy, do you have frame drawings for that ship as i have them for this tanker USNS Mission Santa Ynez (AO-134)?
I got mine from the National Archives.
Floating Drydock may have them too.
Or buy the San Juan Capistrano And copy the hull.
BTW I’m a docent at the Mission in Carmel.
Yes David,
I can use all the help I can get, some of the online downloads are not very clear and leaves a lot of guesswork.
Shane
