Tamiya v. DML/Dragon
I use to think Tamiya made a good 1/35 figure kit. After opening my first Dragon figure kit today I?m beginning to think differently?
I’m doing the Tamiya “Modern Army Infantry” kit right now. Well, actually it’s the “US Modern Military Figures Desert Storm” one, which I thought was going to be a new kit but in reality is nothing more then the “Modern Army Infantry” re-boxed with 2 new figures. When I got it I thought I was getting an updated version with M12 bayonets, M16A2’s and such. No. Just the same all thing.
Anyhow. I notice the Tamiya kit I’m doing is significantly less defined then the Dragon kit I got? The Tamiya is just as detailed, just not as defined. For instance there is very little demarcation between load baring straps and flack vests. You can barely tell the difference between the packets on the flack vest and the flack vest itself. Some times a certain detail may just fade away into nothing. Facile features seem to be hard to distinguish. The neck just melds into the color of the flack jacket without any try demarcation. The gear doesn?t fit right.
Everything on the Dragon kit stands out. Its well molded. Well defined. The facial features are much more pronounced. The gear is better detailed. The flack jacket stands out better.
Is this normal? Are Tamiya figure kits just not that good and DML/Dragon?s are just that much better?
hi tamiya figures are in general not very good , they are stiff and are mostly underscale and all seem to have the iguana thumb sticking up . dragon are far superior in every detail ,just need good hornet heads and hands to complete them cheers ian
I tend to like dragon a lot better, tamiya sometimes is to thick for the scale, but I have never had a problem with DML figures plus you can position the head of the figures in any position that you want instead of Tamiya since it allready comes attach to the body (yeah I know you can cut it off and reposition it but sometimes is just too much of a paint) and the detailing like you said is far better
I’ve got dozens of the DML/Dragon figure sets and the later the release, the higher the quality of detail. While several of them are good enough to be displayed on their own, overall I’ve found them to be excellent additions to the featured model of my display. For example, I’ve used three of the four figures of the Modern US Marines figures to compliment a LAV25 in Operation Just Cause. I didn’t use the SMAW gunner. One thing I will give Tamiya … often their weapons in figure kits are better (sharper detail) than DML but like I say, the newer the DML kit … the less likely that is to be true.
Paul
I have moved my lower quality figures to the backgrounds of my dioramas and try to bring the action and focal points to the better figures.
I like the dragon (DML) kits. The DML kits clean up VERY well and dont require superglue like the resin stuff. I use a large drop of regular model masters glue at the union of the two parts and use the set time to my advantage and move the parts just right.
-Muzzleflash
