hey guys i have some questions about tamiay spray rattle-cans. let me start off by saying that i can’t afford a compressor and don’t own an airbrush so i make do with tamiya spray cans.
question 1: how in the hell do i get a smooth finnish with them, the first coats are smooth but then after about the 2nd or 3rd the surface becomes quite rough and it are no longer smooth, put it this way, it ends up with the texture of your average plaster wall exept a bit finer and it happens every time. Is it even possible to get a smooth silky coat with tamiya spray cans or is it just my fault?
question 2: how much better is a decent airbrush than the tamiya cans and do thay produce a smoother coat? what advantages does the airbrush have over the cans apart from haveing to constantly buy new cans.
quenstion 3: has anyone even used them? if so please tell me how to get the best results with them, i have done 6 models with them and i still can’t get a nice smooth, silky coat like you see on so many pro built models.
Also how do you mask off things when using tamiya cans because every time i take the tamiya tape off the masked area like the canopy, the paint around the edge of the tape flakes and the result is far from a smooth straight edge, even when i use very light mist coats (which tends to add to the problem of a rough finnish).
Thanks for any advice… James
