I am currently working on a Japanese Zero from Tamiya and the main two colors are AS-2 "IJN"Light Gray and AS-21 “IJN” Dark Green. My problem is my local hobby shop and Hobby Lobby do not carry the Tamiya AS paint series. I have the complete X & XF series and was wondering if anyone knew what X or XF colors would be a match to those two AS colors?
Here is a Tamiya paint guide for Japanese Aircraft:
JAPANESE AIRCRAFT
XF11 JN green Upper side of the Navy plane
XF 12 JN grey Lower side of the Navy plane
XF13 JA green Upper side of the Army plane
XF14 JA grey Lower side of the Army plane
XF16 Flat aluminium Silver fuselage without coloring
X13 Metallic blue Interior of the plane
I’ll will try to post the PDF file, it has a lot of information on how to mix Tamiya colors.
Edit: Message me your email address, I have two color charts and the mixing chart in PDF format. The forum does not allow attachments such as PDF or Word.
You may want to have a look at Gray Green XF-76 also. That color was supposedly matched to later research color for the Zero and was released with their new 1/32 Zero kits as a result. XF-71 for the cockpit color, and XF-70 for a topside green if you do a two tone scheme.
ebay is a great source. I took alook and found AS-21 in rattle can only. I’m not sure how you feel about rattle cans. As-2 also only in rattle can. Links are below.
Kinda pricey for Tamiya rattle cans on eBay. Scalehobbyist sells them fat less. Why not ask your LHS if they could order them for you? Or order from any online hobby store.
Thank you Stik…Those colors look like they will match up. When I looked up the two tone paint job I had to make sure I was looking at the Navy colors not the Army colors. They are slightly off in tone.
I found them on Scalehobbyiest site a couple of days ago. I was hoping to find them in a 18 or 23ml jar. But if I need to use a rattle can I will. My LHS would take to long…much faster if I do it. Thank you for the help and Info.
Thank you for the links, it looks like I’ll have to get the rattle cans so I properly finish this build. I want to make sure I use the right colors. Again, thank you for your help. Greatly appreciated.
The grey color that was used on Zeros had a definite green tone to it. Also depending on if the Zero you are working on was made by Mitsubishi or Nakajima will decide on some detail color differences. I have a bunch of Tamiya mix charts to make the right shade of colors. Downside is you have to mix. John
Also the control surfaces are a different shade then the metal airframe
Thank you so much for your time and help in this matter…I went ahead and ordered the rattle cans so I put the right colors on the build. FYI since you were so informative…Mitsubishi A6M5 Japanese Zero.
