Hi All
I have finalised my Tiger 2 after 6 months work and have had her out on her maiden voyage. All went well (although I can’t get my Skysport 6 to work properly) but why is there only ONE BATTERY in them when the Tiger 1 has two? Anyone know why?
Is there an alternative, smaller maybe or one that will work longer. I don’t know when it’s gonna run out and the alternative of putting a spare battery in my pocket feels a bit stupid.
Any advise would be REALLY appreciated, I can post a picture (of the tank not the wife!) if anyones interested.
The Very Best
Dave
Well, an alternative might be having your batteries wired into a switch before they go to the ESC (electronic speed control), and then to the motors.
When a battery runs low, you could then flick the switch, and it would start taking from the other battery supply, thus giving you the same effect as the other tank with 2 batteries.
Another option may be adding cells. Depending on what your motors are rated at, you can add cells that will increase run time dramatically. You may want to see about getting some good 3600 mah batteries or the like, if you arent familiar with these., thay hold alot more “juice” than say your average 20 dollar battery. These are a bit more expensive, but you get the choice of building and wiring them yourself to get the desired resluts, or buying them pre assembled to your liking. Sometimes custom building them is a far better option because you can build them in the configuration to best suit you, and the space you have available for the batteries to be put in. If the tank was designed for 1, you may find this very usefull.
The final option is to wire your motors in series. The tank probably is running in parallel right now. When your tank is running in series, your run times can double, because less battery is used since you can now run 2 batteries withought overloading the motors.
For more info on batteries, visit: www.towerhobbies.com
I hope this helped a little. Although I have never personally owned a tamiya tank, I have 5 rc cars right now, and enough to make 4 more in parts. I mostly drive my clod buster, and race my touring car (tc3) at the local hobbyshop.
regards,
MARC
I have both the M4, which uses one like your King, and the Tiger I. I bought the radios, batteries and charger from Tower and just went with their recommendations.
The M4 battery is stronger. The Tigers two are smaller. I can’t give you run times because niether kit is finished and I’ve only used the batts to test stuff out. Although the Sherman has been on a few test drives around the yard and it seems to last pretty long.
The charger only takes 15 min and can be hooked up to a car if necessary so I never was concerned about it.
The Tiger batteries power the different units seperately, while if your King is like the Sherman you have the Y connector.
My guess is either it’s the older design of the Tiger I or it needs more power.
I’m sure someone here will have the real answer.
Good Luck, post some pics and Welcome!
