I don’t remember if my Tamiya 61114 kit had the lightning strips molded into the canopy or not, but I do remember there being a single line, right down the middle, on the outside of the canopy. That single line is a mold separation line, and pretty much every Tamiya kit has those. Its a little annoying, but not horribly difficult to deal with. If you want a good reference photo for where the lightning strips begin and end, here’s a good one…if you decide to want to simulate them with maybe a partial removal of the parting line.
https://cdn10.picryl.com/photo/1990/12/01/a-plane-captain-polishes-the-canopy-of-an-f-14a-tomcat-aircraft-on-the-flight-1819e1-1024.jpg
To remove the line, start off with a brand new #11 xacto blade and carefully/gently scrape away the parts of the line you want to remove. Stop scraping right when you get it just flush with the rest of the canopy surface. The next thing you’ll need, if you don’t already have one, is a micromesh kit of some type. For canopies, I prefer their sanding stick kit, because it gives you more control over exactly what gets sanded. That way you don’t end up sanding into the canopy frame.
https://www.amazon.com/gp/product/B003ELIO0A/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
With that, you just start with 1500 and work your way up to 12000. I usually do this with running water over my kitchen sink to gently, progressively sand and polish the scraped line so that it becomes just like the rest of the canopy. Switch the direction of your sanding each time you change grits to minimize the fine scratches that will be dealt with at the end. Do this gently and try to follow the contours of the canopy so you don’t end up with little flat spots and distortions. When you’re done, you should no longer be able to see any hint of the parting line, but under the right light you’ll notice extremely fine scratches and swirl marks. That’s where the Novus polishing kit comes in.
https://www.amazon.com/gp/product/B002UCYRZU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
With that, you start with the #3 bottle and work your way to the #1. Do this on the inside and outside of the canopy, so you won’t have to coat the canopy with that awful “Future” stuff. The best method for applying and polishing Novus that I have found is to use cotton gloves. I get out 3 gloves, 1 for each of the 3 grits, and use one finger to apply, one to polish/remove the Novus, and another to do the final polish. Repeat that process for each bottle, and in the end, you’ll have a beautiful canopy that looks like it never had a parting line. You can wash the gloves with your other laundry and reuse them. Just air dry the gloves after washing, because you don’t want residue from a dryer sheet or fabric softener in them.
Here are the gloves I have been using. It also helps to wear a clean pair of them when handling canopies and painted parts to keep fingerprints away.
https://www.amazon.com/gp/product/B00M3P4X6C/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
And here’s what my Tamiya F-14A canopy looked like at the end. Heh…didn’t know about the lightning strips at the time I built it, so I removed the entire line instead of leaving portions of it to simulate the strips…but, you get the idea.
