Today was one of those days where I just had to be building…you know, one of those days where the urge strikes and you are compelled to start up something new? Trouble with that is that it was also conference championship playoff Sundayin the NFL…so while watching the games, I began work on the Tamiya Char B1 bis kit as a way to fulfill the need to build while watching the games.
Here’s the starting point:
Beginning with Step 1, the “caterpillar” style of roadwheels is assembled by creating no less than 32 pairs of wheels, 16 to each side, and the cradle they rest on. Fortunately, Tamiya molded these with very small sprue connection points so cleanup was minimal…but it doesn’t change the fact that there are indeed 32 of those suckers to deal with…at least they are steel and not rubber rimmed! The wheels are not glued into the cradle, only dry fit, and the instructions explicitly say not to glue them so they remain rotatable.
Step 2 calls for the installation of the wheels and their cradle into the lower hull. Since the wheels aren’t glued down, this is a tricky exercise requiring an extra set of hands almost, particluarly since the fit is a tight one. I managed to drop several wheel pairs in the course of doing this, fortunately none went permanently missing. The detail plates for the front and rear are also installed in this step and fit nice and clean.
Step 3 is very simple involving the assembly of the sprocket and idler halves, each of which gets a polycap in the middle. The idlers had a slight seam in the middle that I sanded down out of habit more than anything else as it’s highly doubtful it will be seen on the finished vehicle, but better safe than sorry I guess. Don’t be tempted to remove the “sink marks” on the iders, they actually belong there and were intentionally molded.
Step 4 deals with the assembly of the 75mm gun and the housing/mount for the right side idler along with the left side idler mount as separate pieces. The Lion Marc set replaces the kit barrel assembly entirely, with a brass piece for the gun mount itself and a turned aluminum barrel complete with rifling. The brass piece identically matches the dimensions of the kit piece and incorporates the polycap onto the elevation arms, a perfect solution given the weight to allow the gun to remain positionable. The socket for the turned aluminum barrel needed a bit of attention with a needle file to get it to fit, but that was minor and little CA gel to secure it was all that was necessary.
Step 5 installes the front idler mounts on both sides into the lower hull plate along with the lower side skirts that cover/protect the roadwheels. The instructions say to paint the lower edges of the skirt in flat brown, I believe because these are actually rubberized canvas (or actually rubber) mud/dust covers, but not 100% sure.
Step 6 installs the inner rubber skirts along with the side access maintenance hatch panels on both sides. What’s very ironic to me is that with both skirts installed, the wheels are hidden from view…and are still rotatable but for no real purpose I could see except that they do, in fact, turn. [;)]
Step 7 calls for all the holes in the upper hull, molded as a single large piece, to be opened up with a pin vise to allow the skid plates and other details to be installed. Curiously in this step, they do not tell you to open up the two rectangular panes to create the mud chutes, although the areas are clearly molded for removal. I drilled out a series of holes around their perimeter and then cut through with a sharp knife, then sanded the openings with a sanding stick to complete the job.
Step 8 calls for the mud chutes to be installed, be careful with these as they have to go in just right to align properly. They are conveniently labelled L and R to keep track of which side they go on, but you can still turn them around if not careful which side is top/bottom when you install. The rear fenders/mudguards are also installed into the upper hull along with the track skids, the left side radiator housing, the sprocket drive mounts, front lifting hooks, and two of the rear deck access panels among other small details.
Step 9 directs you to remove 6 rivets that are molded on the rear deck, which does require some care given their proximity to other molded on details, but are taken care of with a sharp knife point easily. The sprockets are installed onto their mounts from Step 10 using their polycaps and no glue. The upper and lower hull are then joined together and while the instructions suggest using tape, I found the fit to be snug and only a little bit of finger pressure required to get a good join.
Step 10 constructs the driver’s hatch and periscope housing along with the two headlights, one standard, the other auxiliary. Since “Marne” has the auxillary, this required opening up a hole in the front hull plate which is installed in Step 11. No pic taken of this step due to its minor nature.
Step 11 installs the front hull/glacis plate, the driver’s hatch, and periscope mount plate to round out the hull armor panels. The fit of the glacis plate wasn’t 100% perfect, some liquid glue had to be employed where it joined the lower hull and on the side, but that’s all…no putty work will be necessary. I also installed the main blackout headlight with the cover in the closed position, although the option exists to install it open with good detail on the light if you wanted to go that route. The front tow bars and hooks are also installed and fit snugly into their designated places. Last but not least, the 75mm gun mantlet is also installed. Since “Marne” didn’t have the pigtail lifting hook, I didn’t add that detail but I did drill out the bolt holes top and bottom that would be present for the weather cover for the gun housing with a small drill bit prior to installation. These holes aren’t marked or called out for on the kit parts, so I had to check the references carefully. The box art is a close, but not perfect, match of how they should be placed.
To round out the day’s activities, Step 12 was completed with the installation of the right side crew hatch, grab handle, and rain/mud shield. The kit parts include a nicely detailed insert for interior detail on this hatch but since no other interior is included in the cavernous space of the hull, I left it on the sprue and just installed the hatch in the closed position.
I have to say that so far this kit has been an absolute joy to build. Total time to get to this point was about 6 hours altogether and there are 9 more steps remaining.
