It turned out pretty well but if you have noticed anything that I’ve done wrong no matter how minor (apart from the MG Shield as that’s been covered) please tell me so it won’t hapen again.
I want to be able to build things like that Jumbo Shermie of yours some day so I need to know where I’m going wrong [;)]
Where the verticalfront of the hull meets the horizontalfront plate there should be a weld representation between the two apparent lines of assembly…across & below the notex light.
Maybe not apparent in 1/48 scale but in 1/35 there should be some visible casting texture on the main gun mantlet. If it’s there, good… but I can’t see it.
The extra “cheek” armor on the commanders station should fit more, how to say it… “snug” against the cupola housing. Check below.
That’s great buddy - thanks. I am always hoping to improve every new build over my last one - obviously [;)] and this is the stuff that needs to be pointed out to me.
Thanks for the links btw. ‘Making’ visual weld beads is something I’ve been looking into and I hope to add a lot of this ‘minor’ stuff into all future builds as it’s what modellers like yourself are looking out for.
Re the MG shield: I know I mentioned the fact that it isn’t correct as it’s standing up on it’s own and I’m now told it shouldn’t do that. Unfortunately the one piece hatch moulding was already glued into place and I didn’t fancy doing a butchers job on it!
If you look at my ‘it’s complete’ post on page 3(?) I mentioned the EP hole on the inside of the MG shield in the text above that photo and named it as something to be remedied asap. This weekend I’ll be sorting that and stretching some sprue for the twin antennae.
