Tamiya 1/350 IJN Tone heavy cruiser WIP
I just started building my Tamiya 1/350 IJN Tone heavy cruiser. This is being built for the Midway group build, but I will be updating this thread with more detailed pics of the build.
I bought the WW2 IJN Navy paint set by AMMO for this build, as well as the Eduard detail up kit for all of the railings. Pictures will be up soon!
I like to do some research on every model ship before i build them. This is my first IJN ship, and first thing I found interesting was that most IJN ships in WW2 did not use black boot topping/waterline stripe, which will make the painting of the hull much easier!
Another thing with the Tamiya kit is that the lower hull anti-fouling red color is way too bright. The IJN ships used a much darker reddish-brown color for the anti-fouling. This color is also obvious in the anti-fouling hull paint that came with the IJN paint kit I got from AMMO. So, first thing I did with this model was attach all details to the hull, and primed it using tamiya surface primer. The primer is currently being given 24-hours to cure and I will be painting it the correct color. Pictures of this will be up in the next couple of days.
Show us the pictures :slight_smile:
Pictures are worth a thousand words.
Cheers.
Here you see the waterline hull that came with the kit and the reddish color it came in. I always do the full hull on these types of kits, but used the waterline part to contrast the correct color for the hull.
Nextt you will see the hull primed and then painted. The paint might look a little off here because it was still drying when I took these photos.
As you can see, the antifouling paint used on the IJN warships was much darker! Thanks for looking! More coming soon!
