This kit was a real gem. Its a top of the range 1/32 Corsair and its every bit the quality for the price I paid for it. If you’re going to splash out on something that will really provide a centrepiece for your collection, you can’t go past this one. I thought the Tamiya 1/48 F-14A tomcat was good… this is better…
Detail - Incredible
Fit - perfect
Instructions - Excellent
Decals - too thick, cartograf are better (only flaw for Tamiya kits damn them…)
Challenge - requires patience but its a very enjoyable build
Result - Very satisfied
For the paints I’ve used a mix of Tamiya XF17 Sea Blue, XF8 Flat Blue and XF2 Flat White in about a 5:2:1 ratio.
The assembly turns out to be multiple kits in one.
There is the cockpit assembly
There is the engine assembly, which I added some fuse wire to as the kit didn’t reflect all the pipes that are quite prominent for radial engines.
The undercarriage
And the final finished product.
Its been a very pleasing build and being a carrier aircraft I didn’t give it the typical pacific island hard weathered look, just a bit of rough marks here and there. I hope you enjoy viewing as much as i enjoyed building.
cheers
BT
