Hello,
I´m going to use Tamiya´s Liquid Surface Primer for the first time, should I thin it or is it right to airbrush it right from the bottle?
Thanks,
Peipus.
Hello,
Thanks,
Peipus.
Tamiya’s Liquid Surface Primer is very similar to the finer grades of Mr Surfacer. I haven’t tried airbrushing it, though I do use it as a spot filler.
I would recommend thinning it for airbrushing. Remember that it’s a lacquer based product, so don’t use regular enamel thinners, it won’t work.
If you haven’t read Swanny’s summary about Mr Surfacer, I’d suggest having a look - in my experience, all points are applicable to Tamiya’s Liquid Surface Primer. I’d also suggest that when you get to actually spraying it, do a few test shots on some scrap first, to see how it flows and how it lays down on the subject. Also, do a forum search on “airbrushing mr surfacer”. This will turn up some other members’ previous experiences with it. General opinion seems to suggest Mr Surfacer needs about 30% thinner to airbrush cleanly, so I would imagine that would be applicable to the Tamiya product.
Good luck
Phil, thanks for the info and the link, that was some good reading.
Peipus.
