Superglue debonder ?
I seen a you tube video , I just don’t remember which one . He superglued photo etch , then use some kind of debonder to remove superglue from surrounding area .
What would that be ?
Do they work ? I know what I saw . Not sure how good
Like Bob Smith Un cure debonder .
Thanks
Rick
Yes, superglue debonders work. In the application mentioned, one would have to be careful to keep the stuff away from behind the PE piece you are attaching.
They are available at many hobby shops.
Thank you Don
Rick
nail polish remover does the same thing ., cheaper too .
Don is correct-Use caution-I applied a little too much once and ended up melting the plastic underneath,
