Suggestions for a thin consistency glue/cement
Hi there. This is maybe a little off topic…
I have designed a set of chess pieces in a 3D CAD system. I left a pocket in the base of the pieces to add weight. My idea is to add steel shot (or lead shot if I can find any) into the cavity then pour a glue/cement into the cavity containing the shot to seal them inplace.
My question is: What is there in the way of cement that is of a thin consistencey which will flow into and around the shot? I have used two part epoxy in other applications, but that is more like honey and a pretty short pot life. I’d really like a thinner product like a medium weight oil or even water. I will use some type of ABS plastic when printed so the cement should not damage, soften or deform the base.
Suggestions?
Larry
Try thin CA glue and use an accelerator once you have it all where you want it and not to shift placement.
Try one of the new UV setting adhesives.
Pick the correct one for your materials, applies about like a gel CA.
Expose to a UV source, matter of a minute or so.
Or sunlight, 15 minutes or so.
Loctite makes it, plenty of others. Advantage is it’s pretty thin and won’t set until you want it to.
