I have a 1/35 scale plastic figure i have painted with acrylic modelmaster paints.How do I strip the paint to start over fresh??
Alot of people here swear by oven cleaner, ive never done it myself so im not sure how effective it is. But ive used Detol (disinfectant) in the past, only issue i had was a slight softening of the detail.
I have had good success soaking the parts in Windex, to soften and remove acrylics.
For acrylic paints, Windex or denatured alcohol. Either one should work.
Do you remember that old series of International House Of Pancakes commercials that touted IHOP as the “International House Of Omelets / Crepes / Entries / Whatever” ??? In this case, you need Easy-Off Plastic Model Stripper (AKA oven cleaner). Wear gloves.
I have used elo paint remover from Flouqil will work on any type paint try it. ACESES5[::DD0]
Super Clean degreaser is the best followed by Easy-Off oven cleaner in the original yellow can.
Both contain Lye and work well on paints.
