Strapes for Equipment
So If I wanted to put strapes on my Abrams to show that they are being held on by the strap, what could i use, and how would I do it?[:D]
You could use aluminum foil, the kind that you cook with, and just paint it the color that you want. Masking tape might work well too, especulay Tamiya tape. For any buckels, small peices of photo-etch might do the trick. Hope this helps!
i use very fine masking tape ( 1mm)
You can also get Graphics Arts tape. It comes in all sorts of narrow widths and glues adn bends well. Wine bottle foil works well too. Masking tape as well. Some people use regular paper too.
Thanks everyone, I’ll try some of those Ideas.
I use thicker aluminum foil. You can usually find it on top of yogurt containers and so forth. Just wash it, and use. It’s a little thicker than normal aluminum foil, so it looks nice, holds the shape, and is a little easier to work with as well.
Thin foil on top of 1 lb. cans of peanuts works great. Might also try the foil on top of Pringle’s potato chips containers. All work well.
