I was having some trouble with some areas of putty on a recent kit and thought I’d try my Dremel tool out on it. I ended up gouging jagged crevices in the body and have more to putty now than I started with.
So, do you guys use Dremel tools for fine areas or detail sanding or do you stay away from them all together?
I use my Dremel for surface texturing and for hogging out large areas of plastic or resin. Otherwise all my contour sanding is done with various grits of sand paper and various grits of sanding sticks with some work being done with files.
No reason to rush anything and you have complete control over the amount of material you remove. The sandpaper and files remove plenty.
Does you dremel have a variable speed on it? If not, you can find a plug in rheostat in the electrical department of a hardware store that can reduce the speed toa crawl making clean up a bit easier. That said, most of my clean up is with #11’s, files and sandpaper.
I bought the Dremel used at a show in 1982 and have had the rheostat on it for close to 10 years. That said, if I had to replace the tool, I would go with a cordless varaible speed model.
