Howdy!
Starting work on what should be the fifth entry in my Year of the Axis Build with a really neat looking seaplane, the Heinkel He115 B-1. This warbird was noteworthy in its role against shipping in the North Atlantic along the convoy routes from the US/UK to Russia, and the particular aircraft that I am modeling reportedly was involved in the attack on PQ-17 in 1942 (a disastrous convoy for the Allies).
The kit is by Special Hobby in 1/48th scale.
I did not hesitate to pick this one up when I first saw it a few years back. The box art was very appealing even though I was not that familiar with the 115.
I have built a couple of Special Hobby kits in the past, and know full well the challenges that these can present. These are not cookie-cutter kits. They are certainly not Tamiyas, or even Monogram. They typically do not include things like locator pins or any kind of attachment stubs for things like wings or, in this case, pontoon pylons.
Well, to be fair, there were tiny protrubances on each of the pylons, but no way would those have provided near the support necessary to keep the pontoons in place on this model, as it is quite large and likely will be pretty heavy, as models go.
I’ve had a construction plan in the back of my mind for this one since I first inspected the plastic several years ago. Now I am embarking on it. This entails reinforcing the wings with plastic tubing and the pylons with brass rod, and drilling many, many holes in otherwise perfectly good plastic.
So to this point in the build I have managed to get all those holes drilled and cut out lengths of both plastic tubing and brass rod. I also have taken an unusual build approach by attaching the lower wing parts to the fuselage parts sans any other work being done in the fuselage and without the upper wing parts. This is to accomodate structural support work that I expect to have to do to keep the wings in place.
Here are all the pylons with the brass rod inserted.
I’ve done a lot of test-fitting of pylons and pontoons, nothing glued into place yet.
Here are a couple of shots of what I envision for the wing support plastic rod.
That’s it for now. Not a drop of primer or paint yet. Nothing done with the interior. Really just trying to get the engineering done of reinforcing these pylons and wings.
This probably won’t be a traditional WIP with lots of photos of things that we see on builds every day. I’m not detailing anything within the cockpit or fuselage, as the greenhouse will be closed up and prevent any of that kind of extra work from being visible. This may also turn into a slow build for me, given that temperatures have reached into the 90s this week and it is just too dad-gummed hot to be in the workshop for too many hours.
Finally, I’m researching the hairspray method for painting the white camo on this bird. The white was field applied and subject to pretty heavy wear and tear, so should not look factory fresh. I’m going to attempt to capture that look.
